Aykfc
- Apr 5, 2015
- Scottsdale,Arizona
Hello. I have an 1875 10" Logan made around 1969. It's in really good condition and I got it 18 months ago. The issue I have is with the MT3 taper inside the head stock. There is significant wobble that you can see. Tried it with multiple MT3 tapers and all of them have issues. I measured just inside the spindle and the indicator moved .008 as I turned the spindle. Outside seems to be good. I have cleaned it inside and still have the issue. I feel several grooves as I feel further back. I thought they were how the spindle was designed but I am wondering if it's possible if a previous owner decided to bore out the spindle to try and get it a little bit wider. I will try and take some pictures if it might help. I don't know what a normal 10" spindle should look like so it's hard to tell. If the inside is screwed up and I find a replacement spindle, how hard would it be to replace it?
