DavidScott
- Jul 11, 2012
- Washington
I have a production part that I need to slot .235" deep in 6061 with the least cutter force and absolute least lifting from the cutter. I think a corncob rougher is the best tool design for the job, correct me if I am wrong, but the only one I have found is Accupro from MSC. Suggestions please! This will be a long running job, like endless, so shaving a few seconds off each part is worth it.
This is a .24"ish x 1" x 6.25" bar that I am making from a 12"x12.9" plate held down with vacuum and stops/clamps on all sides catching the bottom .05" of the plate. All surfaces must be machined and cosmetically appealing. I am currently using regular length corncob mills from Maritool but when I try pushing them, more than a .0014" chipload, they snap off at the end of the flutes. I can't saw it because I have a vertical mill and will be slotting in both X and Y axis.
