I would like to make a 3/4" boring bar with about a 14:1 bore ratio. The purpose of the bar is to bore a 12" deep hole on the lathe into wood. The wood can vary in hardness and species. The hole will also be taperd. The boring will follow a 3/4" drilled hole. The taper will be approximately .014" tpi . With the small dia at 3/4". I can not afford a solid carbide or any kind of devibe bar so it needs to be shop made. My thoughts so far is to start with 7/8" sqaure bar about 17" long. I would taper 13" of it the same taper as my bore. Then drill or slot the end for a piece of high speed steel. My question is what type of steel would give me best results, what type of tool geometry would give best results for long boring and would resist chatter. I usualy grind my tools for wood with lots of pos top rake. Is lots of pos rake more coducive to chatter than say neg or neutral top rake? Any suggestions welcome. Thank you
