I have built a small shop onto my garage (23' x 24') and have a 17" x 74" LeBlond lathe and a series 1 Bridgeport. Also plan on doing what welding I need to do to support the machine work. The ceiling height is 13' at the peak. I am pretty crowded with press, saw, etc. and am looking for a way to remove smoke from all 3 generating sources. That small a shop gets cloudy pretty quickly! I think a rolling unit would take more floor space than I have at present.
Also, a pleated filter would clog pretty quickly with the oily smoke from the lathe and mill. I could go through the roof if there was something that would swivel/raise/lower. Then air would be unfiltered but would be pulling heated air out of the shop in the winter. I have a MicroAir unit at my day job but the mounting is far different from what I could pull off at home.
Any suggestions would be appreciated, Quicky
