Hello! I'm new on this forum. Glad to see there is an active machinist forum here.
I'm wondering if you could give me some tips for improving tool life when turning stainless steel (usually 316, sometimes 904)
The tool starts to chip/wear out after like 10 cuts, it still works but the finishing is worse and it makes more noise.
So the insert I'm using is KNUX 16 04 05R11 2025
Cutting speed is usually around 80-100m/min with a feedrate of around 0.25mm/rev
Tend to take 2mm deep cuts, can do 2.5-3mm but it seems to work alot better at 2mm
This is manual turning with a pretty old lathe (Colchester Triumph 2000 if I recall)
So yeah, I don't know if its actually that bad but I tought I'd ask cuz I feel like I might be doing something wrong.
Any ideas?
Any ideas?
