doobin
- May 25, 2014
- Southern England
Today's job is a run of fifty 10x40 flats, each with a top 21mm hole and four lower 17mm holes. These will be erected on site, and round bar inserted and welded to form what is know in the UK as parkland or estate fencing.
In an ideal world I'd own a punch. Instead I have a mill and an MT3 annular cutter holder. I knocked up an extending stop to bolt to the table and this works great for quick repeatability. I didn't want to use an oil as coolant when drilling as then I would need to clean this up post machining to be able to weld and paint.
For this job I've just used water, misted through an airline coolant spray thingy. It worked fantastically. I will give the mill a good oil up when I'm done, but it got me wondering- is there a better alternative for this sort of job? Do soluble lubricants need to be cleaned off parts pre weld/paint? Wikipedia says it was common in days gone by to add baking soda to the lubricant water to reduce rusting- is this true? Minimal rusting of the stock before painting is also desirable, but a little is unavoidable given that it will be assembled bare outdoors and not painted until it's all done and looking good.
