dkmc
- Jan 13, 2002
Need opinions and engineering help.
So I bought a commercial mower, 60 inch front deck, and a mechanical
PTO. The PTO shaft is driven off the engine crankshaft with a 3 groove
"B" size belt, the kind that has the top covering that connects all 3 belts
and is one piece. Essentially it's similar to 3 separate B size belts.
Anyway, to explain the current arrangement:
This mechanical PTO consists of a PTO shaft inside a tube with
roller bearings on each end. The rear of it has a 7.5 inch 3 groove pulley and up toward the front of the tractor is a U joint and open shaft to connect to the mower deck. There are two lower pivot bushings on this tube, so the tube can move closer and away from the engine pulley. A couple control rods and an bell crank work to move the tube, and then lock 'over-center' when engaged to keep the belt tight between the pulleys.
There is a brake bracket that has a piece of brake lining on it (a block) so when the shaft moves toward the crank pulley (belt slack) the PTO pulley rubs this block and it is 'supposed' to act as a brake....it does not
The PTO shaft spins a bit all the time.
The pulley end of the PTO shaft, has the bushing. It's worn out of its mind
and most of the movement is taken up, not tightening the belt, but taking up slop in the bushing.
I had to take it all apart to get the shaft out, and even had to remove the engine to get access.
I'm thinking this arrangement is flawed by design, and now am leaning toward an electric clutch-brake like most mowers have.
My main concern is space to retrofit the C-B unit, and sizing it to handle the load. I plan to call Ongura and get help with sizing.
The unknown:
Problem is, the engine is a 32HP diesel, aprox 46ft/lb of torque.
It now has the 3 B size belt pulleys on it. Most of the Ongura clutches are
2 B grooves at best. I found a belt HP rating chart, and it seems to show that each B size belt is capable of only around 9-10HP at 3600RPM. Are these published numbers very conservative ratings for the belt HP ratings? It seems in mower or Agricultural applications, they always use belts way beyond what rating tables show as max.
I'm leery about only 2 belts, as there are now 3, and it is a major project to change the belts. Maybe 2 or 3 separate belts could be changed in place, but surely the 3 groove belt that has the top joining covering, would require major wrenching to get the new one in place.
I want to fix this thing ONCE, and do it right. I'm too far in to just fix the bushing and hope the brake setup will work as designed. I don't think it ever did.
dk
The unknown:
dk
