One of the hiccups is I am trying to work around is 1/2" diameter stock, that is the base material size we use for much of our product. If I go with a 12mm thd. then I need to turn the stock diameter which I don't want to do, that causes other complications. The 1/2" stock is a tad undersize for a 13mm thread but seems to work out well for the parts I have built.
I did try a 1/4 BSP but using 1/2" diameter base stock left me with loose connections that I wasn't happy with. And Bobw is M12.7 x 1.27 a real thread? Or were you just being cute describing a 1/2-20 in metric terms? I looked but found no info on such a thread.
Given a choice I would use 1/2"-20, that is the perfect thread for the parts, but we are working with some global marketing companies and they insist everything for export needs to be metric. According to them there are plants where it's not allowed to have anything but metric tooling and hardware, hard for me to believe but I guess in this age of global standardization maybe that's what it's coming to.
These parts are all components we will build in house, yes we will be single pointing the male threads but would like to use a tap on the female threads, as far as production runs. We also do a lot of custom work and it would be nice to have taps and dies to use on the engine lathes instead of having to single point threads.
