Peter from Holland
- Jan 15, 2005
- The Netherlands
Friend of mine called the other day
He has a shop that also works on big theatrical constructions and sometimes if he needs someone to brainstorm about a problem he calls This time he was in the far east working on a big turning stage with a 26mtr diameter
The problem was that the steel 300mm wide ways the rollers were on were not perfectly in line The stage was in place already and almost impoosible to remove
They wandered 5mm on hight on that diam Also the inclined angle was not perfect As far as I undertood the ways were made from sheetmetal 35mm thick It was connected to the floor in a irreversable way The filling underneeth was not perfect So holes were drilled in the ways and the gaps under the ways are filled with epoxy He had contacted a compagnie in Holland that could do on site milling But the problem is time and off coarse money
A Japanese compagnie wanted about 5times the amount of the Dutch compagnie
Was there a alternative that he could do himself ?? We discussed several options
A way that seemed possible to me was with a big beltsander 400mm wide A drum as big as possible Driven by big motor 25Kw or so
The whole connected to the stage on a swivelling arm
On the shaft of the grinding drum you connect a tracer that follows a steel ring next to the steel ways say 25mm wide that is adjusted level to the allowed tollerance That will be a challange of its own because of the tight space But they were able to measure it within the needed accurracy so it must be possible to bolt down a adjustable construction out of several segments Probbably needs a ground surface
Then turn the stage with the beltsander on and keep adjusting the tracer till the whole way is ground
What do you experts think of this idea ? Possible or doomed from the get go
Please ask questions if the set up is not clear Englisch is not my best language
Peter
Peter
