I've got a 1" x 1.000" lead Thomson rolled screw mounted to a linear stage that I'm building. Makes a ton of racket when it spins above 750rpm. Is this typical of these screws? The 1" x 0.25" lead screws of the same make are a bit quieter.
The noise is definitely coming from the nut (non-preloaded single two circuit nut with typical ball return tubes).
Time to look at Hiwins...
