machining nitronic 60
Results 1 to 9 of 9
    Aug 2006
    greensboro,northcarolina
    2,101
    102
    376
    Default machining nitronic 60
    The little bit of information I can find suggest using speeds and feeds like 316 stainless. Anyone with experience, your advice would be welcome. I will be turning and internal grooving 2 inch bar stock in a Daewoo with plenty of hoursepower, rigidity, and synthetic coolant. What grade and coating of carbide insert ? RJT
    May 2003
    Iowa
    9,644
    2836
    3485
    Nitronic 50 & 60 is pretty nasty stuff to machine. We use a ton of it literally. 316 machines like butter compared to this stuff. I'm not at work, so I don't have the numbers (home with a broken ankle). I'm guessing 80-120 SFM with carbide with a fast feed. This stuff will work harden if you look at it wrong. We have never been able to get real good finishes, so we grind anything that requires 32 or better.
    If you have a short work piece, you don't have to worry about wharpage. Nitronic is strain hardened and will wharp all over the place if you take heavy cuts.
    Good Luck!
    JR
    Aug 2006
    2,101
    102
    376
    Wow, I'm getting different information from Kennametal. Just got off the phone with applications and they suggested 550 SFM .016 - .018 IPR for rought turning and KC9925 for grade. What equipment are you turning with? What size workpiece? RJT
    May 2004
    Nebraska
    413
    13
    Kenametals recomendations are on the high end by my estimation but no more than 15%.
    Nov 2007
    Alabama
    1,378
    125
    204
    RJT,
    If you will give me some contact info I'll send you some toys to try on this .
    Curtis
    Oct 2007
    Richland, WA
    1,048
    38
    10
    Geez, I don't remember Nitronic 60 being so difficult to machine when I turned it about 9 months ago. In fact I remember telling my customer to bring more because it was "pretty nice to machine".
    A quick look at the program I ran shows that I roughed at 200 SFM @ .009" IPR, and finished at 300 SFM @ .002" IPR.
    Dec 2003
    Bel Air, MD
    882
    10
    5
    I turned a couple of shafts out of it on an old Monarch and it cut like butter....It's tough to drill, but with carbide tooling, it's not bad. The HSS grooving tool worked fine, too. Took a nice finish, too.
    Andy Pullen
    Mar 2003
    Vermont
    435
    87
    83
    Default my experience
    I mistakenly accepted a Nitronic 60 gear job, cutting teeth only. Was unable to cut with TiN coated M4. Used advised surface footage and ruined a cutter in less than a minute.
    Aug 2006
    2,101
    102
    376
    Exkenna, sent you a PM with contact info, but have not heard from you. What toys did you have in mind? RJT
