Please forgive the incredibly ignorant question but what is the difference between the two. When I read the definitions for each I think 'but that's a machinist, or but that's a millwright'. Can someone please enlighten me. I'm a Safety professional and do not want to offend my clients when speaking about their profession.
Thank you kindly!
a millwright is a field machinist. they can take drawings, order supplies, fabricate parts, install and align parts in machines, test and debug machines and maintain machines as needed.
often they are more a jack of all trades and master of few. but they often can find solutions faster when everything is not perfect. think mcgyver . welder, steel worker, machinist, surveyor, many trades often done. but not everybody is the same with same abilities
optical transit has bad 2 speed high precision screw, think of design, create drawing, order materials, fabricate a 127 tpi tap and create 127 tpi screw and split nut, install in transit, calibrate and use transit. or design and fabricate a special high precision level using castings made in home made foundry
few years later by running a cnc making 11 ton parts and week after doing manual machining, week after making programs for small single piece jobs.
many millwrights are like Mcgyver. often looked down upon as inferior machinist even though they may have made many many things that are astounding and awe inspiring.
