Magnetic base portable mill??
Results 1 to 19 of 19
    Apr 2007
    Dublin Texas
    2,539
    1353
    900
    Post
    I work at a powerplant. When a field job comes up all the oldtimers would say "Sure wish we had that mag base mill they sold during investment recovery." They would then launch into the story about how great this little mill was. It had about six inches travel on each axis, and was light enough for a man to carry. I personally have never seen such an animal. I am beginning to believe it is kin to the much feared,photographed, stuffed and mounted, yet never seen breathing, WEST TEXAS JACKALOPE!
    Has anyone ELSE seen a mag base mill?
    i_r_machinist
    Feb 2007
    Kansas
    512
    99
    146
    Post
    Maybe they were talking a portable keyway/slot cutter not magnetic though.
    Clamp on unit with about 6 inches of travel.
    BTW Mag mills can only be operated by Jackalopes.
    Oct 2005
    Albion, Michigan
    1,437
    50
    Post
    Are they talking about a mag base mill or a mag base drill?
    Regards Walt..
    Sep 2003
    Roscoe, Illinois
    1,506
    43
    Post
    We had one sort of like that at Ingersoll but with a bridgeport head on it and about 24 inch of travel on one axis, only 3 or 4 inches on the other. It was clamped or bolted to the piece needing treatment. It was used for rework on the road and rarly on the assembly floor for those little discrepancies that sneek in now and then. It was all black and oily/dusty so that you couldnt touch it without getting yourself all messed up too. It finally disappeared from our storage, probably just got left at one of our larger customers after a job.
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4054
    Post
    I so happens I have one. It's called a TransMill. Cute thing. All aluminum scructure except for the ways which are cast iron side bearing against brass inserts.
    4 speed, 1/2 HP infinitely variable DC motor, about 1/2" mill cap, Erickaon cllen spindle.
    Jun 2006
    Dayton OH
    144
    Post
    Would this happen to be it?
    http://www.tripleellc.com/transmill.html
    Apr 2007
    Dublin Texas
    2,539
    1353
    900
    Post
    Not a keyway cutter, portable clamp down mill, or mag base drill. All of which we have and use.
    It IS the machine that Howitt posted!!!!
    Now if I can just find a jackalope to run it!
    Thanks!
    i_r_machinist
    Jul 2006
    Clover Hill district, WI
    2,304
    7
    Post
    Actually there are a number of such animals ,
    there is a large company called
    In-Place-Machining
    they have a shop in Milwaukee and I think at least a few others in the east.
    In the field theres alot of machining that has to be done "in-place"!
    that is there specialty.
    http://www.inplace.com/machining/index.html
    http://www.fieldcmm.com/
    searching out-fits like this may turn up alot of interesting stuff.
    (I worked in a power-plant too In the 70s)
    and would have stayed there if I had had any brains.
    Apr 2007
    Dublin Texas
    2,539
    1353
    900
    Post
    We have a Faro CMM. Both laser and a couple of arms. Unfortunatly I'm the only one that can run them so I get alot of crap jobs. Still better than production though. Never did field machining till I came here ('99). I love it. It amazes me everytime I hold a +/- .001" with these small machines. And some that are not so small.
    have fun and thanks
    i_r_machinist
    Oct 2004
    St. Peters, MO
    2,965
    157
    140
    Post
    "I am beginning to believe it is kin to the much feared,photographed, stuffed and mounted, yet never seen breathing, WEST TEXAS JACKALOPE!".....
    ....I now live in Missouri!
  11. #11
    Apr 2007
    Dublin Texas
    2,539
    1353
    900
    Post
    Add "and had messages posted by,"
  12. #12
    Oct 2003
    East Peoria, IL, USA
    5,263
    300
    708
    Post
    hmmm i smell "nitche market opportunity" in that machine. [img]smile.gif[/img]
  13. #13
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    10,966
    4075
    3797
    Post
    I've often mentioned having a versamil with about 4" x 16" travels (or thereabouts) and have used it for portable milling & boring. But it has to be clamped or bolted down.
    OTOH, I recently retired a 6 x 18 mag chuck when the handle got too sticky to move.....
    hmmmm, now if the magnet were to be cleaned out & re-greased, and suppose the versamil track was bolted down to the magchuck base with it flipped over....
    smt
  14. #14
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4054
    Post
    Hmmm Steven. Coudst be thou hast a glimmering?
  15. #15
    Dec 2004
    uk
    12,487
    3493
    5603
    Post
    were i use to work we had a 2 meter fero arm on a 500kg lifting magnet, apart from being vertualy impossipble to carry it was awsome! simply take laptop arm and a small genny to object to be mesured and scan away!
    on a mill though a magnet might be more aggro than a couple of right angle brakets and a asortment of plates u can weld - heavy tag up to suite. you dont have the travells the fero arm did! mag drills are great on big open structures but try something more confined and they can be a right pain! a magnetic base on the pictured mill probaly seams a nice idea except when u come to put it into practice due to the oftern weird and wonderfull places - objects u need to clamp to.
  16. #16
    Apr 2007
    Dublin Texas
    2,539
    1353
    900
    Post
    The worst part of field achining is not, "Do I have the proper tool?", but more often, "Which tool will fit in this space?". Not to mention room for the machinist.
    The hardest job I had was drill out three broken bolts that I had to use a video camera to see. I'm laying on this piping, reaching behind a valve,drilling out this bolt with a dental drill, while watching a monitor. It taught me a great deal of respect for those doctors that do that type of thing.
  17. #17
    Nov 2015
    GERMANY
    Hello, the company BDS Machines from Germany have developed a new cross table base magnetic drilling and milling machine. If you are interested in the portable magnetic base mil please take a look at the machine. the model number is MAB 825 KTS, this machine has a cross table base which enables the machine to move X & Y axis (120 mm), you can attach an end mill tool on this machine to make Slots (key slots). The MAB 825 KTS can also perform drilling, tapping, reaming and countersink. This machine is complete made in Germany and is available in USA also. Please check the video for more explanation.
    Website: Magnetic Drilling Machines & Annular Cutters | BDS Maschinen GmbH(R) - Made in Germany
    Video:https://youtu.be/H1t9v-ZmUW8
  18. #18
    Mar 2007
    Custer WA
    369
    44
    52
    Looks like you are about a decade late to the party.
  19. #19
    Oct 2005
    9,863
    17013
    5077
    Quote Originally Posted by Michael Edwards View Post
    Spammer is dredging up a couple of the postings as of late.
    I wonder if they know how badly they are damaging their companies reputation ?
    Let's hope corporate management does the right thing.
