Magnetic Flashlight System
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Dec 2010
    Western WA
    78
    Default Magnetic Flashlight System
    Not sure if this is the right section or even the right forum but here goes:
    Greetings,
    I am working on a project for a friend of ours who is a long haul trucker.
    She occasionally delivers cargo to unlighted docks and with only the running lights on the trailer to see with, it can be tough to nudge up to the loading dock.
    She came up with the idea of two led style flashlights with attached magnets that she could simply stick on the sides of the trailer doors - which would light up the area behind the trailer enough to see as she maneuvered it back toward the dock. She thinks if someone came up with some sort of a kit, it would be a big seller at the big truck stops.
    I suggested the standard 2 D-cell flashlight currently made but she didn't think they were bright enough.
    So, with that in mind I bought a couple of small led lights and magnets at our local Harbor Freight store today. Now I need to figure out a way to attach the magnets to the barrels of the flashlights. I plan to use epoxy but need some sort of mounting bracket/gizmo in between (with one side flat and the other curved) to do it right.
    Any ideas?
    Thanks for reading.
    Mike
    Attached Thumbnails Attached Thumbnails magnetic-flashlight-project.jpg   magnetic-flashlight-project-one.jpg
    Jul 2010
    South Carolina
    190
    392
    68
    Google image search "tactical flashlight mount" for starters.
    Nov 2005
    Hudson Valley, NY
    923
    566
    Big rigs dont have back up lights?
    Jun 2004
    Melbourne Australia
    5,191
    Quote Originally Posted by RetiredLE View Post
    A large cable tie base might work. Like this, but bigger.
    http://solutions.3m.com/wps/portal/3M/en_US/3MElectrical/Home/ProductsServices/ProductCatalog/?PC_7_RJH9U52300RQ50ISL93Q0T24Q5000000_nid=GS9M4FM Q2JgsG5D0T5FX3WglKRXFXTC7HVbl&soloMode=true
    Cheap and readily available. A large one should cradle the flash light while the epoxy sets.
    Phil.
    Jan 2012
    Nebraska, U.S.A.
    646
    239
    155
    Snap on, Mac, and a few others offers a 3" chromed round magnet base with velcro strap for flashlights.......
    Ill try and take a pic of mine
    Jan 2012
    Nebraska, U.S.A.
    646
    239
    155
    But honelty, a mount made to a suction cup (the style with handle to lock the cup...also available at harborfreight in orange) would be better.....a lot of doors are aluminum......
  7. Likes JoeE. liked this post
    Jan 2012
    Nebraska, U.S.A.
    646
    239
    155
    The velcro wore out so I added a zip tie
  9. #8
    Oct 2006
    Woodland Hills, Ca. and some times Hutchinson, Ks.
    2,110
    438
    Considering "most" trailers are FRP or aluminum a magnetic flash light would not work so well. Clip on on vacuum mounts sound like a better idea. I too wonder about a trailer without back up lights?
    Steve
  10. #9
    Dec 2010
    Western WA
    78
    Quote Originally Posted by APD View Post
    Surprisingly enough, no. They do have on the tractors themselves but not on the rears of the trailers. So when the loading dock is dark it can make it difficult to see what you're doing.
  11. #10
    Dec 2010
    Western WA
    78
    Quote Originally Posted by machtool View Post
    Phil.
    That might work.
    Attached Thumbnails Attached Thumbnails magnetic-flashlight-project-mount-one.jpg
  12. #11
    Dec 2010
    Western WA
    78
    Quote Originally Posted by Steve in SoCal View Post
    We mentioned that to her. She tells us that there is usually enough steel on the rear of the trailer to facilitate using a magnet.
  13. #12
    Dec 2010
    Western WA
    78
    Thanks to all for the input thus far.
    A thought came to mind that scope rings might work. The magnet could be attached to the rail section.
    Attached Thumbnails Attached Thumbnails magnetic-flashlight-project-scope-rings.jpg
  14. #13
    Jan 2012
    Nebraska, U.S.A.
    646
    239
    155
    If you were to use scope rings, check out UTG....they are cheap and beefy.....
    I would mill off the rail section and tap a hole or two in the bottm to screw to a magnet base.....
    General Tool makes magnets with a threaded and non threaded holes.....mill scope ring, drill/tap attach magnet and light
  15. #14
    Jul 2005
    Cottage Grove, MN 55016
    6,375
    3397
    3759
    Default Snap on Has it
    I just bought a magnetic based rechargeable LED swivel base light from Snap on for $59.00. Its great working on machines and I would check with them before designing one. I've never used it in the dark of night though.
  16. #15
    May 2010
    Midwest, USA
    153
    5
    54
    Erick Magna Holder
    I have a couple of just the bases that "stick" pretty well.
  17. #16
    Sep 2005
    il.
    6,558
    29
    1175
    go to mcmaster carr and pick out magnets that mount easily
    McMaster-Carr
  18. #17
    Jul 2011
    Brusly, LA
    618
    19
    249
    Nebo make several lines of led flashlights with magnets in the base already.
  19. #18
    Jul 2004
    Southeast Michigan
    6,337
    226
    1343
    Harbor Freight should have a magnetic LED flashlight right at the checkout.
    They are $3 each or something like that. One of the few items I still buy there, but I keep losing them because they are magnetic and stick anywhere.
  20. #19
    Jul 2008
    Philadelphia
    1,860
    487
    409
    Home Depot has a LED light that is a cylinder about 2" dia. by 8-9" inches long with a very strong magnet in the base. It is quiet bright and comes with an attchment to charge it from the cigarette lighter (if you even get one these days ) or a standard 120 VAC outlet all for about 20 bucks. I really like it no batteries to purchase always ready to go. the only problem that I have is that socket for re-charging is located in the center of the magnetic base, and after using it around the shop I always have to clean out bits of metal (never had a problem but a big enough peice could short it I guess). All that aside it sounds perfect for her.
  21. #20
    Apr 2002
    Syracuse, NY USA
    9,588
    16
    537
    good idea. Having driven trucks on dark winter nights, with everything covered with frozen mud, blah!
    anyways, how about having both magnets and spring clamps for attaching?
