Magnetized 4140
Results 1 to 4 of 4
Thread: Magnetized 4140
    Jun 2008
    Wheaton , Illinois USA
    Default Magnetized 4140
    I have noticed, to an annoying degree, that when machining 4140 pre-hard that it will become remagnetized. I demagnetize it, machine it more and viola! Back to being a magnet. Does anybody have any knowledge of why this happens and is there a procedure to stop the remagnetizing once and for all?
    Jun 2001
    St Louis
    16,846
    1428
    2583
    Soft steels do NOT magnetize well as permanent magnets. Iron pretty much does not at all.
    Hard steels do.
    4140 PH is hardened, although it is not very hard.... Therefore it CAN magnetize, and it is no surprise if it does. You can magnetize some things weakly by pointing them North and whacking them with a hammer... machining a part lasts longer than a whack with a hammer.
    Mar 2005
    Kansas
    6,713
    356
    2899
    I have noticed straight tooth cutters tend to magnetize parts more than spiral tooth cutters. Form cutters such as gear cutters are especially bad. The teeth are just a series of little rotary hammers, each one imparting a small amount of magnetism.
    May 2003
    Iowa
    10,169
    3315
    3959
    If you're using an insert cutter or a fly cutter it's worse.
    Just make sure your mill table runs east to west, and you machine only when there isn't a full moon
    JR
