Making bolts with lathe
Results 1 to 9 of 9
    Aug 2013
    Croatia
    5
    Default Making bolts with lathe
    Hi, can someone give me some links or literature or give brief description how to make bolts with lathe?
    I am new to this forum so I apologies if thread posted in wrong place.
    May 2010
    Denmark
    17,505
    3419
    5408
    Quote Originally Posted by Vale View Post
    I'd start with a hexagonal steel bar and take it from there
    I'm thinking "Are you serious?" YouTube and Google are available in Croatia.
    Apr 2010
    Bay area
    346
    60
    127
    You could start with hex stock the size you wish the bolt head to be, then just turn the stock to the major diameter and either single point thread or just use a die to cut the thread.
    If you use round bar there is just an extra step on the mill, you can use a hexagon collet block (that accepts a 5C collet) and just clamp the block in a vise and set the "depth" then cut one flat, and rotate the hex block with your bolt still in it until you cut all 6 sides.
    Aug 2013
    Croatia
    5
    Quote Originally Posted by Gordon B. Clarke View Post
    Haha , yes we have google and youtube in Croatia but I am writing my final work and I can't find literature on this subject in croatian or english language, but thanks with your advice
    Quote Originally Posted by 358Mustang View Post
    Dec 2006
    NW Ohio, USA
    289
    25
    We use cold formers and roll threaders to make bolts here up to 1 1/4" dia. Haven't seen anybody try and make a bolt on a lathe since high school shop class 40 some years ago.
    Aug 2013
    Croatia
    5
    Yes, we make bolts with cold formers and roll threaders for big series but we can use lathe for making small series of bolts and bolts which we can't make with cold formers.
    May 2010
    Denmark
    17,505
    3419
    5408
    You know this but not basic threading?
    Thread cutting on a lathe - YouTube
    thread cutting on colchester lathe - YouTube
    LATHE MACHINE THREADING - YouTube
    It's always easier to start with bar that is hexagonal.
    If you Google "Lathe threading" you'll get over 1,000,000 hits.
    Why do I get the feeling you just want to copy text rather than write it yourself?
  8. Likes digger doug liked this post
  9. #8
    Aug 2013
    Croatia
    5
    As I said I am writing final work on subject ''Technology of making bolts'' so I am done with cold forming and roll threaders. Therefore I must also write something about bolts made with lathe.
    I won't and thanks for links, I was getting bad results because I Google wrong term
  10. #9
    May 2010
    Denmark
    17,505
    3419
    5408
    Maybe I'm getting sentimental in my old age but you're just about becoming likeable
    Good search words for Google and YouTube:
    Lathe, bolt, machining, cutting, screw, thread, threading. beginners etc.
    Not sure about the USA but here in Europe when you say "bolt" it usually means a screw plus a nut. Notice the "usually"
    Gordon
  11. Likes Vale liked this post
