Making propane torch
Results 1 to 15 of 15
    Feb 2008
    Los Angeles Ca
    102
    Default Making propane torch
    Anybody know where to find information on making propane torches?
    Im thinking about modifying a and existing torch or making new, also thinking of making a torch with multiply flames and bent for more rapid production of annealing brass for personal use.
    Sep 2007
    Washington
    4,571
    92
    1081
    Search for "homemade propane torch". There are several sites detailing construction and modification of the "Ron Reil" burner.
    I made a 2-burner forge a few years ago. Works great.
    Regards.
    Finegrain
    Dec 2004
    uk
    12,410
    3430
    5534
    You can also get just the burner heads from companys like siviet and add them to your own manifolds.
    Jan 2007
    1,219
    273
    405
    Quote Originally Posted by robbor View Post
    What size and thickness blanks, maximum, do you want to anneal? This has everything to do with properly designing a system
    May 2008
    Tennessee
    95
    40
    The Reil EZ burner is just that. Cheap, too.
    http://www.abana.org/ronreil/burner.gif
    May 2009
    Canandaigua, NY, USA
    2,435
    102
    925
    Neat! Not to hijack the thread, but does anybody know if there are any on-line plans to machine a glass working burner? The nice ones are way out of my price range, but it's more complex because oxygen is involved.
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    This guy has Reil-type burner plans, even a mini, and tube burners. He sells a few of the parts that are harder to come by. http://www.zoellerforge.com/
    Mar 2007
    South Jersey
    421
    Quote Originally Posted by USMCPOP View Post
    Nothing he sells is hard to come by, if you look around a bit. I just built the mini sidearm he designed, and most of it came from McMaster. The key part is the tapered Tee. Got to be Ward brand. PM me if anyone wants more details on my part sources, or about what I learned building one.
    I think this design is easier to build, and much more flexible on the gas tips (tweeko mig tips) and adjustment of the tip location, than the Reil.
    Here's mine:
    John
    Jul 2004
    central NC
    2,375
    16
    528
    If your "rapid production for personal use" is brass cases, this might work also.
    http://www.youtube.com/watch?v=iy6OwiuWV7A
    Steve.
    Nov 2004
    Webster Groves, MO
    6,208
    1483
    2493
    Quote Originally Posted by Conrad Hoffman View Post
    What kind of burner are you looking for? Single tip burners are easy to make. I have made lots of them for special purposes like glass tubing sealing machines. If you don't want to get into the complexity of a bench burner like the Bethlehems, which are great, but complex, you can make a bench burner with a single center tip and others in a circle around it. You can buy needle valves at a welding supply store and control them separately, only limited by the number of valves you want to fool with.
    If you want to pursue this, send me a PM so we don't clutter up this thread.
    Bill
  11. #11
    Feb 2008
    Los Angeles Ca
    102
    Quote Originally Posted by SteveF View Post
    Steve.
    Thats what im making steve, I already turned and milled the case holders. I have 3-4 ideas on means of spinning the cases as the annealer turns. What im also thinking of is a multi flame torch head to have flame on both sides
  12. #12
    Nov 2004
    Webster Groves, MO
    6,208
    1483
    2493
    In the glass tube sealers and flame polishers I mentioned above, we used a shoe matching the radius of the wheel with a rubber strip glued to the inside of the shoe. The tubes rolled against it and made one rotation when they had traveled a distance equal to their circumference. Also, if the cartridges don't have big rims or too much taper, you can load them horizontally in a hopper and have them drop into notches in the wheel, pass by the flame, then drop off into a bin. You can scoop them off with a ramp to avoid a drop that might dent the mouths.
    Bill
  13. #13
    Mar 2003
    NE Iowa, USA
    80
    5
    robbor,
    I just finished making a propane burner. I modified the Oliver upwind propane burner to be straight line, with a 6 foot handle. As he suggested, used a #57 drill for the orface, but drilled into an 1/8 pipe cap.
    The regulator is my acetylene regulator with the output fitting changed to a male flair fitting to mate with the LP hose.
    Sorry, no pictures, but check out www.backyardmetalcasting.com/oliverburner1.html
    mm
  14. #14
    Aug 2005
    Toronto
    4,816
    2718
    3001
    Neat! Not to hijack the thread, but does anybody know if there.........
    people always say things like 'not meaning to hijack the thread but' ....rather than say that, which shows you know hijacking isn't appreciated, just don't do it......just start a new thread. There's a huge array of talent and knowledge and your Q will get much more exposure that way.
    (no offence intended, stuck in China, grumpy from jet lag )
  15. #15
    Mar 2005
    Raleigh, NC
    74
    Default keith porter design type
    I made a couple of Keith Porter design burners that have a relatively high efficiency compared to the usual pipe fitting designs.
    I uploaded 2 pics that I have handy. The first is the burner, but does not have the sleeve that slides over the ports to adjust the airflow and is missing the flare on the end of the tube. The second is a pic of the accelerator tube that increases the flow of the gas stream.
    - Reed
    Attached Thumbnails Attached Thumbnails ff-burnerassembly2.jpg   ff-burnergastube.jpg
