Marking-out blue: best recipe
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Jan 2012
    Sheffield, England
    78
    165
    79
    Default Marking-out blue: best recipe
    I have a bag a prussian blue powder and a bottle of ethanol. What is the best recipe for making marking-out blue? What ratio of blue to alcohol?
    Richard
    Mar 2001
    Switzerland
    2,423
    2015
    998
    Will this be for scraping work or something else?
    Jan 2010
    Indianapolis, Indiana, USA
    5,475
    2426
    925
    If the OP can't determine the proper ratios, the Prussian Blue is useful as an antidote for thallium posioning.
    Thallium poisoning - Wikipedia, the free encyclopedia
    May 2005
    Austin, TX
    4,404
    1259
    1188
    Prussian blue is a nasty mess. Assuming you mean spotting for scraping, Canode water-based spotting compound is what you want:
    Power Scraping Accessories & Aids | DAPRA
  5. Likes rpchristian liked this post
    Jun 2004
    Melbourne Australia
    5,148
    He's in England. He will want the drying one for doing layout and scribing work on. Ethanol and blue powder. The problem is, once the alcohol evaporates, there's nothing to hold the pigment on. Nothing to stick it to the metal.
    Its almost before my time, but I recall old guys mixing there own with methylated spirits. (Denaturated. Alcohol in the U.S) shellac flakes, and powder to make a kind of varnish, that would stick and hold once the fluid dried off. Don't recall the recipe, it was just a splash of this with a splash of that until you were happy with it.
    Can you even buy shellac flakes anymore. I could be wrong but I think the non drying / scraping blue is called Engineers Blue in the U.K
    Regards Phil.
    Feb 2006
    SW PA
    6,027
    1266
    726
    You can also spend a dollar or two and buy either a little tube of Dykem paste, or a spraycan of Dykem. The tube stuff takes forever to dry out, the spray, within minutes.
    You WILL need cleaner to remove the spray after it dries.
    You can, of course keep on with your scheme to use up the powder. I am cheap, too. I probably would, but it would not be as convenient as the spray.
    George
    Apr 2006
    Manchester, England
    6,907
    856
    3862
    Depending on the size of work you are doing you can buy a sort of magic marker style pen these days. We buy them all the time, the tip is about 3/4" by 1/4" wide and the tube is about 5" by 1". They're specially made for marking out. Obviously they're not made for large castings but for small work and erasing in-correct lines on large work they're fantastic. Easy to use and the blue is good and dries very quickly. I just can't bring to mind the makers name but I can find out for you.
    Regards Tyrone.
  9. Likes Laurentian liked this post
  10. #8
    Feb 2013
    midlands,UK
    3,018
    1520
    1461
    20 odd years ago when I worked in a development lab with a small workshop we used to have a really bright blue "lump" that we bashed a bit off and mixed up with a solvent ,I'm not sure if it was ethanol or not, but I don't remember it to be an exact science. I assume the "lump" started out as the powder that the OP is talking about. I liked this stuff as it seemed to stay on the job better than the proprietory darker blue stuff.
    In the works where I did my time they used a white paint like liquid on the bigger jobs.
  11. #9
    Jan 2012
    Sheffield, England
    78
    165
    79
    Quote Originally Posted by Tyrone Shoelaces View Post
    Thanks Tyrone, that would be interesting to know.
    Yeah, using up the prussian blue was a cheap solution, but it's turning out to be very messy. As lazlo has pointed out, the alcohol evaporates leaving a fine, bright blue dust that transfers instantly to your fingers and then to anything you touch. In a few seconds you've covered your entire workspace in the blue smears. Don't recommend this. Anyone reading: stick to the spray.
    It might still be useful mixed with oil to make a spotting compound, or engineer's blue, as Phil points out. I'll try this out.
    Richard
  12. #10
    Feb 2007
    upton ma
    1,664
    47
    173
    In regards to one of the side question - Shellac flakes look to be easily available at least in the US (and it looks like some of the companies will ship internationally), price seems to be on the order of $30/lb +-
    Dykem layout fluid is available in red and blue, spray can as well as brush top bottles and wide felt tip tubes. 4oz bottle is all of about $6 from Enco, not sure on availability in the UK but hardly worthwhile to be making your own.
    Paul
  13. #11
    Sep 2006
    SE PA, Philly
    5,125
    923
    1592
    Perhaps this will help. Not sure that it's completely apropos, as prussian blue is insoluble in water. So I think you need something to keep it in suspension.
  14. #12
    Oct 2004
    Lancashire, UK
    1,323
    64
    476
    The stuff that Tyrone is talking about is very good, but you can often get by using various sizes of 'Sharpie'. The small ones are only useful for small areas of course - you want the bigger ones for most things. They make marking stand out pretty well, but the drawback (a big one!) is that they will wash away with coolant, which could be inconvenient. Personally I wouldn't bother with any of the old witches brews. The newer ready made layout dyes are OK, but some of them can crack away from the lines that you mark - the marker pens don't do this. If you are doing layout on big castings then you need something else, but I doubt if this is you problem at the moment.
  15. #13
    Jul 2007
    UNITED KINGDOM
    4,282
    2006
    1804
    If you want to turn it into layout blue, mix it into some French polish or meths and shellac to a dark blue, water thin consistency. Spotting blue would use a very small amount of ISO 220 way oil with the blue thoroughly mixed into it. To be honest, in Sheffield, I'd expect to be simpler to buy layout blue in a number of handy engineering suppliers (there's two or three here in Rugby that carry it). Chronos as an example for mail order or Cromwell tools in Effingham St, Sheffield and mail order, spring to mind.
  16. Likes rpchristian liked this post
  17. #14
    Mar 2007
    Bozeman Montana
    9
    Default Big pens for marking
    Regards Tyrone.
    Sharpie pen in various colors and styles
  18. #15
    May 2009
    Canandaigua, NY, USA
    2,442
    103
    927
    You seem like the sorts that would really like Henley's Formulas, Recipes & Processes. Try to find an old copy, say pre 1940s. Another good source of chemical goo is the Laboratory Arts & Recipes section of a good chemical engineering handbook like Lange's or maybe CRC. In this case older is better than newer. Not sure if they have the exact bluing formulas, but they have enough on paint and glues to get you started.
    Personally, I usually use a Sharpie.
  19. #16
    Sep 2004
    south SF Bay area, California
    1,918
    109
    564
    sable --
    Did the "blue lump" solution you describe leave a blue film, or a copper film? One common layout fluid used in the days before Dykem was a fully-saturated solution of copper sulphite (commonly called "bluestone") in water, or sometimes in VERY dilute sulfuric acid.
    I have a slightly-clouded-by-time memory of a 1960s classroom demonstration, in which a walnut-sized lump of bluestone was crushed to a coarse grit, poured into a clean cough-syrup bottle, clean water was added to nearly fill the bottle, and then ten or twelve drops of battery acid. The bottle was then capped and shaken well, producing a clear blue solution with little chunks of copper sulphite on the bottom. When swabbed on a clean iron or steel surface, the solution deposited a copper film that clearly showed layout lines.
    John
  20. #17
    Apr 2006
    Manchester, England
    6,907
    856
    3862
    John, That sounds like the stuff we used to use for checking wether a component's chrome plating was still existing or wether it had been worn away. Regards Tyrone.
  21. #18
    Oct 2004
    Lancashire, UK
    1,323
    64
    476
    You see references to Copper Sulphate used for layout in old books, but really I think that it has gone the way of read lead and oil paste for scraping, white lead for centres, horse dung for casting bronze etc. Maybe someone still uses these somewhere but there are much simpler and safer (and less smelly) modern options.
  22. #19
    Jun 2012
    Minnesota, USA
    1,877
    356
    674
    Quote Originally Posted by machtool View Post
    Regards Phil.
    You can still buy BullsEye premixed shellac. Just add some of the Prussian Blue to the shellac and see what it looks like. Since you aren't trying to use the shellac for fine woodworking, age won't make much of a difference.
  23. Likes mike 44 liked this post
  24. #20
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,747
    1328
    2194
    Dykem by the bottle or spray can is relatively cheap, but it goes bad with age
    and becomes mostly transparent in time. I hate throwng out most of the
    hardly used bottle or can after 2 years.
    dk
