moespeeds
- Mar 3, 2011
- Cherry Hill, NJ
Hey guys I want to replace a tunnel stiffening panel in my Corvette track car with something stiffer. Right now it's 3/32" Aluminum, grade unknown. I see panels sold online in 1/4" and 3/8", 6061 T6 for around $400. The panel is flat and fairly easy to duplicate, but locally I can only get 5052 in 3/8" plate in the size I need. I'm completely ignorant to the properties of either grade, but I do know 6061 T6 is the stronger of the two. No welding or anything like that will be required, just cutting to size and drilling some holes. 3/8: is as thick as I can go because of clearance issues, so making it thicker won't work. Think I'm ok with 5052? Any advice is appreciated...
