zimbo
- Apr 22, 2017
- Richmond, VA
Hi all,
I am looking at purchasing my 1st mill and possibly a second lathe. I run a tobacco farm here in Zimbabwe and most of my machining is to repair or make broken parts for various implements and gadgets on the farm.
I don't know much about mills but kick myself weekly for letting a bridgeport with non working DRO slip through my fingers for U$2500. So now am looking at an Indian milling machine, HMT, FN2U machine # 2955. Don't know when it was made, possibly 70's or 80's? There is no tooling for it so will be looking for machine vise, rotary table and collet system, etc. So the question is, how decent are these machines? Not sure if it is going to be too big for what I need but at $1800 dont think I can complain. It is currently getting its electrics checked out as during the move, the seller cut some cables. How do I check how worn the bed and head is? What other things should I be looking for. Have found a company in the US that stocks some spares, but they haven't responded to me regarding parts, operators manuals and spec sheets. Contacting Indian companies is a joke, like Alibaba. What are your thoughts.Is this machine a knock off of a western machine?
I already have a Colchester Master Mark 2 square head and runs reasonably well, other than noisy and a leaking a bit of gear box oil, which I have found is common for these English machines. They can conquer the world, but can't make non leaking machines )Only issue with this lathe is bed is a bit small for some jobs and the bore is small too (38mm) as I use a lot of 40-50mm stock. The same guy has a Chinese lathe, CY- L1660G, early 1990's model and reasonable shape. Same price as the mill, only lacking the 4 jaw. Many comments I have read here mention rather buying English and American old iron is better but here in Zim there are loads of old machines that have been worked hard and in very rough shape. I was thinking of getting this as a second machine so don't have to send out axles and harrow shafts to other engineering shops, about 2.5 hrs drive away.
Has anyone had any experience with these machines? Any other thoughts I should be looking at and options? My back ground is a farmer and 1 started machining several years on a small Colt, (myford super 7 knock off) self taught and watching the pros on you tube.
Other related questions....
My wife is currently in the states putting a container together of household stuff to ship here and was wanting to buy a bunch of second hand machine tools that I guess some shops sell by the bucket load for $20. I bought some cutters and tapered drills couple of years ago from a chap in Virginia. wish I had bought more but kida of heavy to take on the plane. Has anyone got contacts who deals in this stuff?
Will try to figure out how to post photos for ya'll to see.
Thanks for the help.
Greg
Greg
