Trip59
Cast Iron
- Mar 2, 2011
- Middleburg, Florida, USA
Been away from things for a while, finally getting back to rebuilding my VN #12 and it has a new home it needs to move to. The location is half over an existing ledge (large garage) about 3 1/2" above the floor. I'm not worried about the slab, but this means that I have 18x27" of Van Norman base that needs something under it, as thin air won't support it.
In trying to determine the best direction, a few thoughts came up including modified taller feet/levelers, building a heavy steel box (I have a bunch of 3x3x1/4 angle sitting around) under each corner or across the front, or what seems easiest on first look, concrete.
Talked to a friend who appeared to know a thing or two, but 'a quick form and a couple bags of quickrete' seemed a bit lacking. I'd think I would need to drill in some rebar, scarify the existing (have bonding agent on hand from another project) and perhaps the crack resistant fiber reinforced pre-mix? How far past the base would I need to go?
Top heavy 200lbs of equipment on something I'm unsure of kind of bothers me, thoughts on the best approach and material to bring support under the front half of this machine?
Trip
Trip
