smootz
Stainless
- Dec 5, 2005
- Southern Ohio
Marvel series 8 Mark 1 vertical band saw. Next to the hand wheel is the carriage feed worm gear. The operating manual says to check and fill the reservoir annually. It doesn't really give a good description of the desired oil level. Filling it completely as insinuated causes oil to run out around the shaft. Does anyone know how much oil they want? Since the worm is on top only the gear is in the bath unless the reservoir is actually "full". The exploded parts view shows no seal around the shaft.
Thanks, SCOTTIE
Thanks, SCOTTIE
