ctyleruf
- Apr 23, 2012
- Charlotte, NC
Hi guys,
I'm trying to machine some carbon fiber sheets to make CF wing frames. I've posted some pics of my first attempt. It went okay but I need a better way of fixturing the sheets. I begin with facing the 0.8mm sheets to 0.15mm with a 1/4" flat endmill. I then proceed with cutting the inner contours of each wing with a 1mm endmill; followed by the outer contours to release them from the sheet. I am using a small table top CNC Baron at 1500rpm. Each side is 1mm wide and 0.15 thick except for the triangular base; which is the original 0.8mm.
I plan to try a double sided tape method to hold them down next. I would like to get a tape that holds, but also doesn't leave a residue on the frames. It's also necessary that they be removed easily, possibly with acetone.
I thought of a vacuum chuck system but when I get to the through contours I wouldn't want to damage the chuck.
Any fixturing suggestions would be helpful. Also, tool wear with eventually be a problem. Any suggestions regarding tooling would also be helpful. I don't know if diamond coated burrs will cut at these speeds (plus they're sort of expensive).
Thanks.
PS: I understand the hazards associated with the process. I'm taking the proper precautions.
Thanks.
