mwierowski
- Feb 11, 2018
I have a acquired a U.S. Burke Machine Tool Co. Millrite MV1 Vertical Mill that hasn't been assembled in 25 years or so. I found a PDF version of the manual online (http://www.neme-s.org/Shaper%20Books/millrite-manual1.pdf) and it says to lubricate the spindle by removing the plug on the rear of the quill. The problem is there appears to be something in the center of the plug that is preventing a 5/16" hex wrench from getting a good grip on the head of the plug. I have tried a few different hex wrenches and none of them will insert deep enough into the hex on the plug. My concern is the head of the plug is also starting to strip.
I have used penetrating oil and let it sit for a few days as well, but so far nothing I have tried to remove this plug seems to be working. I was wondering if anyone had any other suggestions short of drilling it out?
My next course of action was to try a left handed drill bit to see if it would get enough bite on it to back it out, but I hesitate on this as I am not sure how thick the plug is and not sure how deep I can drill into it before hitting something that should not be drilled into. And I would like to avoid getting chips in the spindle itself if I can avoid it. I also want to locate a replacement before I go this route as well.
Here is a picture of the plug I am referring to:
Thanks for the help,
-Mike
-Mike
