stoneaxe
Stainless
- Mar 2, 2010
- pacific northwest
Been wondering on this- have any of you tried using molybdenum disulphide as a way lube? (moly Dee. or any other moly bearing oil)
Specifically as a vertical way lube on mills- the mill has a hand crank lift, and must have several hundred pounds of weight to move, maybe more with vise and part. This results in a small slip-stick effect if the gib is adjusted for minimum slop. Any reduction in friction on the ways and gib would be welcomed, especially as the machine has no quill.
I am using vactra 2 now. Thanks!
