motion guru
- Dec 8, 2003
- Yacolt, WA
We have an older Mori MR2000 2080 lathe that was purchased at auction several years ago. We went through it, repaired a number of things, and have been happy with it, but I have always thought that the spline drive for the spindle has been too loose and it has been getting looser and looser the more use it gets.
I took some time to look at it and now and thinking we better fix it before it breaks. (sorry no photos just yet)
The pulley looks to have a pressed in section that is mounted to a poorly made spline. It may well be that the previous owner cobbled this together. At any rate - my thought after looking at it is that we will need a new spline input shaft into the gearbox as well as the spline driver presently pressed into the pulley.
This looks like it was designed to house a slip clutch or ??? Right now it is solid driven and we will likely swap out the across the line reversing starters for a drive to allow smoother acceleration and automatic braking - but all the same, I'd like to know what was originally here.
Does anyone know the purpose of the spline? Why couldn't it have been a smooth shaft with taper lock? (unless there was indeed some kind of clutch plates originally used here)
