Morse taper to 5C
Results 1 to 4 of 4
    Mar 2008
    Wenatchee, Washington
    18
    Default Morse taper to 5C
    Can someone tell me where I can purchase an adapter that convert my lathe's MT5 spindle taper to the taper appropriate for closing a 5C collet? In other words, I want to use 5C collets in my Morse taper lathe, and I need an adapter.
    Thanks!
    Feb 2006
    Indiana
    11,798
    414
    3029
    They are on eBay from time to time. The trick is that different lathes have different dimensions on the approximately 5MT spindle bores. The adapters have to have a shoulder so they can be ejected from the spindle. If the adapter is a few thousandths too small at the big end of the taper, the shoulder will keep it from going into the spindle far enough to get tight. If you specify what lathe you have you may find a seller that can guarantee his adapter will fit.
    http://cgi.ebay.com/NEW-5C-SPINDLE-A...QQcmdZViewItem
    http://cgi.ebay.com/South-Bend-10-5C...QQcmdZViewItem
    http://cgi.ebay.com/SOUTH-BEND-LATHE...QQcmdZViewItem
    Larry
    Jan 2003
    Columbia Missouri
    772
    34
    107
    Buy a soft morse taper adapter, cut the tang end off, and make you own. It does not take long to do, and you know it fits your lathe. It was one of the first things I made- and often used.
    Apr 2003
    Topeka KS
    1,221
    105
    71
    I have heard that GRIZZLY will sell just the adapter from their collet attachments. I was able to get one off Ebay.
