Results 1 to 19 of 19
Like Tree2Likes
  • 1 Post By Michael Moore
  • 1 Post By pistonskirt
Thread: Moto Guzzi factory film
    Michael Moore is offline Titanium
    Jun 2004
    San Francisco, CA
    2,998
    Default Moto Guzzi factory film
    Here's a 1956 film that starts and ends with some GP footage and
    shows the manufacturing, inspection and assembly of parts for a
    500 Moto Guzzi single engine.
    Uomini e Motori ( Fabricazione Moto Guzzi )
    https://www.youtube.com/watch?v=GpCyUebmU8A
    cheers,
    Michael
    Lofty likes this.
    SIP6A's Avatar
    SIP6A is offline Stainless
    May 2003
    Lambertville, MI USA
    1,171
    The Machine at 2:07 is a SIP HYDROPTIC B Jig Borer.
    jlrii's Avatar
    jlrii is online now Cast Iron
    Dec 2007
    Massachusetts, USA
    251
    I have never seen a fluid bore mike like that before (6:19). Besides that, I have to say I would not want to be needle bearing guy, would drive me nuts.
    JR
    jim rozen is online now Diamond
    Feb 2004
    peekskill, NY
    20,196
    And the machines earlier on, had bacon slicers!
    The bore mike was an air gage. The air pressure was measured by a manometer, which is
    why you thought it was some kind of liquid being used.
    jlrii's Avatar
    Dec 2007
    Massachusetts, USA
    251
    I see said the blind man...... A blind man who has not had to work to those tolerances. Thanks!
    JR
    pistonskirt is offline Hot Rolled
    May 2004
    Plymouth, Devon, England
    898
    Thanks Michael, that was an interesting video........I did not know that split cap rods were run with needle rollers
    Have fond memories of a Mk1 LeMans on which I had some fun.
    regards
    Brian
    bcloweia likes this.
    Jun 2004
    San Francisco, CA
    2,998
    Hi Brian, I spent some time this afternoon helping a friend who bought my SP100 project.
    Some of the single cylinder Guzz race engines used Hirth face-serrations and differentially-threaded bolts to hold the two sides together at the middle of the crank pins, the pins being integral with the flywheels. But that was with one-piece rods. Carcano didn't always follow the beaten path.
    *****wrong -- I was thinking of the NSU racers which used the Hirth couplings, but Guzzi did use the differential-thread bolt to clamp the pin to the flywheels - sorry for the mixup - MM*****
    I've got an assortment of Guzzi racer photos in
    Index of /graphics/MotoGuzzi
    there are some scans of factory line drawings of the internals of 1950's works single engines in there; "mg195xxxxx" file names.
    cheers,
    Michael
    Bob E is offline Cast Iron
    Sep 2006
    Middletown, PA
    367
    Two questions:
    1. Is this a lapping procedure?....
    2. What exactly is being ground here..the involute tooth face?....
    Feb 2004
    peekskill, NY
    20,196
    "I did not know that split cap rods were run with needle rollers "
    Sigh. Yep, usually with the big ends solid. Like my older bmws. That means
    the crank has to be pressed up. The crankpins, needles, and rod ends form the
    bearing assembly and the clearances are in the tenths.
    Which means MY bike has to have its crank apart - just tore it down after a
    failure. A bearing retainer screw dropped out, and jammed the oil pump
    gear (driven from the front of the crank).
    Locked the gear solid, stripped the teeth and blew it up. Total oil failure, by
    the time I got the bike home from work it was in rough shape.
    Newman109's Avatar
    Newman109 is offline Stainless
    Sep 2006
    Sacramento County, California
    1,742
    The single cylinder Moto Guzzis that were sold in Chicago when I was a kid there were called the Falcone (Falcon). They were popular and there were several dealers. The engines that I saw were 500cc with Del Orto carburetors. The engine featured open, hairpin valve springs and I recall that the large chrome flywheel was outside and ran backwards in relation to the wheels.
    As far as I know, Moto Guzzi no longer builds singles but those were beautiful machines with lovely red enamel finish and gold pinstriiping.
  11. #11
    Mud's Avatar
    Mud
    Mud is offline Diamond
    May 2002
    South Central PA
    9,632
    [QUOTE=Bob E;1870344]Two questions:
    That's gear shaving. An improvement after hobbing, faster than grinding.
    Looks like it, I never saw it done quite like that.
  12. #12
    Jun 2004
    San Francisco, CA
    2,998
    Speaking of lapping, is that what is being done to all the wrist pins loaded into slots between two plates at about 6:33?
    Also, I made an edit above to correct an error about the use of the Hirth coupling on the singles.
    cheers,
    Michael
  13. #13
    DaveE907 is offline Titanium
    Sep 2007
    Spanish Springs, NV
    2,196
    Quote Originally Posted by Michael Moore View Post
    cheers,
    Michael
    Yes, the wrist pins were being lapped to diameter and surface finish.
    Cool video. It was "interesting" to see a jig borer used in a production setting, a first for me.
  14. #14
    billmac is online now Hot Rolled
    Oct 2004
    Lancashire, UK
    507
    Quote Originally Posted by Bob E View Post
    Two questions:
    Click image for larger version.
    That looks a bit like Reishauer gear grinding, but I can't make out the machine.
  15. #15
    Peter S is offline Titanium
    May 2002
    Auckland, New Zealand
    3,851
    Quote Originally Posted by DaveE907 View Post
    Dave,
    I am not so sure - I reckon "The Genovoise" is making a jig or fixture of some sort.
  16. #16
    May 2002
    3,851
    Quote Originally Posted by pistonskirt View Post
    Brian,
    Hardly in the same league....but I recently repaired a 1980's Tecumseh 3hp 85cc on my post hole borer - "All Needle Bearings" says the label. The con rod is aluminium with removable cap, there are replacable hardened shells in the rod for the needles to run on. The shells include side faces and look to have been pressed from say 1mm steel. It might sound cheap, but I bet it was quite a feat to produce something so simple without any machining (that I could see).
  17. #17
    rammerc is offline Cast Iron
    Jul 2004
    St. Pete. Florida USA
    378
    Default Video
    Michael,
    Really enjoyed the video and the first part brought back a lot of memories. Back in the 60s I owned two Norton internationals and a 58 Manx.
    Rick
  18. #18
    Jun 2004
    San Francisco, CA
    2,998
    Rick, did you race your Manx? A friend let me race his Garden Gate Manx once, it was fun and quite a treat to get to ride an expensive bike like that.
    The last 1950s works Guzzi singles are for me the pinnacle of the bikes of that period, even over the Guzzi V8. Ing. Carcano was one of those rare Renaissance designers who could do both engines and chassis, and he was very clever and innovative on top of that.
    cheers,
    Michael
  19. #19
    Jul 2004
    378
    Default Video
    Michael,
    Never raced the Manx. Bought it for a buddy to race but the deal never panned out. I had wrecked my Norton 750 and traded the Manx to Bob Schantz at Sport Motors to cover the repairs and he tossed in a little Ducatti to sweeten the pot. About that time I got drafted and needed a car and traded the International and spares for a 59 Porsce 356. Bob Scanntz later opened Domiracer Inc in Cinti and sold the international to berliners in NJ. not sure who ended up with the Manx.
    Wouldn't we all love to have some of our old bikes back ? Now my better half wonders why I collect what I do and hate to part with anything ----
    Rick
