Mounting dial indicator directly in line with mill spindle?
Results 1 to 17 of 17
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    Default Mounting dial indicator directly in line with mill spindle?
    I needed to mount an indicator directly in line with my mill spindle. The clamping area is under the dial but I noticed the tip had the same thread as the plunger, so I put the tip on top of the plunger and mounted it upside down in a collet. The plunger is now spring loaded up so I put a rod down the spindle with enough weight on it to hold it down. Of course it reads backwards but it's gonna work.
    I've never seen or heard of this before, anyone? Is there an accessory to screw on the top? I see threads there but couldn't find anything on line.
    Jan 2002
    West Coast, USA
    7,269
    352
    4179
    A lot of dial indicators come with a screw-on cap, long enough to cover the travel. That would mount in a collet and should be concentric with the tip within a few to several thousandths. You'd preserve the proper orientation of the dial and plunger.
    You could of course make a fixture to hold the indicator (flat back mount might be best) and contrive a concentric spindle mount to whatever accuracy you wish.
  3. Likes Terry Keeley liked this post
    Dec 2010
    WA, USA
    1,512
    2005
    1030
    Lots of drop indicators are supplied with a closed tubular cover (attached at the threads you mentioned) to protect the back end of the plunger. They're light gage metal and suitable for your purpose, with care. A quick look into the Mitutoyo catalog suggests that the current offerings are molded plastic and tapered, so not good for what you're doing.
    Depending on your talents and priorities:
    Option #1, call Mitutoyo Tech Assistance/Parts and see if they could help with a replacement part.
    Option #2, buy another indicator with the appropriate configuration.
    Option #3, make what you need.
    Jan 2002
    West Coast, USA
    7,269
    352
    4179
    Just to add, I'm pretty sure the covers on the longer throw (say 2" and up travel) versions of both Starrett and Mitutoyo still have the metal caps. Maybe a good excuse to buy one . . . they're handy if you don't have DRO's on all your machines. And a same brand 1" to 2" long cap should still fit your indicator's thread.
    Feb 2005
    Owl's Head, Maine
    1,990
    288
    502
    Quote Originally Posted by extropic View Post
    Here's a "Like" for Option #3.
    -Marty-
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    Thanks for the reply's.
    I found the cap, as mentioned another brand might be better to mount in the spindle but I don't think those threads are really meant for a mount:
    Mitutoyo, Product: Dial Indicator Spindle Cap
    I could make something, but as Pete said there's no guarantee that the finished mount would be concentric to the plunger if I just attached to those threads. Something that clamped to the bottom with an arm that went around the dial would be better (again as Pete said).
    There's probably a specialized indicator somewhere that mounts the way I want but for this little project my "hillbilly" set up will do.
    Oct 2017
    Indiana
    35
    36
    16
    OT but is that a 8525 or 8530 Clausing? I haven't been able to find anybody else with one.
    -Ed
  9. #8
    Nov 2002
    St.Louis, Missouri, USA
    1,855
    104
    401
    The cap or cover for those indicators are about a standard diameter but not really designed for mounting. The guys I used to work with thought it was a good idea to put them in a ER collet chuck and would crush the cover, it can be done tightening by hand only!
    Dan
  10. Likes Terry Keeley liked this post
  11. #9
    Sep 2007
    Northern Illinois
    3,140
    1480
    1668
    I don't see a problem with what he's done... indicators are spring loaded, will read accurately in any position. I've had one mounted in this position for years as the depth stop on a sinker EDM with no ill effects.
    Yeah, having the trade name upside down looks funky, but it gets the job done.
    Dennis
  12. Likes Terry Keeley liked this post
  13. #10
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    Quote Originally Posted by CNCBurnout View Post
    -Ed
    8520 with the MT2 quill, super accurate little machine.
    Resto here if interested:
    Clausing 852 Restoration - International Waters Community
  14. Likes CNCBurnout liked this post
  15. #11
    Apr 2008
    Helmer, Indiana, USA
    1,167
    242
    454
    I went through the same exercise not too long ago, couldn't find what I wanted either. Had to make a quick and ugly adapter.
  16. Likes Terry Keeley liked this post
  17. #12
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    Quote Originally Posted by Kyle Smith View Post
    Cool! Do you recall what the thread was?
  18. #13
    Jan 2002
    West Coast, USA
    7,269
    352
    4179
    Not Kyle, but my recollection is that the Mitutoyo uses a non-standard metric rather than ANSI thread. You'll have to measure the diameter and pitch. The pitch might be something like .5mm.
    Whatever metric thread it is, just guessing by its nice companion Clausing mill, that you might not have metric threading on your lathe -- and while an approximation (like 48 tpi) might work in a short and loose thread -- you might lose a bit of concentricity??
    Could be Ebay will have a Mitutoyo or other longer travel indicator with a good metal cap? If you grip gently and down toward the threaded portion of the cap it should be fairly concentric and with little danger of crushing the cap. Not too different, just a bit thinner and with close fitting threads, than the adapter Kyle made.
    Not sure what back is on your present indicator, but I've seen a variety -- including one that has precise adjustments for centering. Again, might find something used and cheap; just for the back? That's if you make your own holder.
  19. #14
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    Quote Originally Posted by PeteM View Post
    I have an Emco Super 11 lathe so I can do any inch/metric threads but I think I'd still want to check if the plunger was concentric with the mount if I did Kyle's mod.
    Better to make a mount that grabs it under the indicator as designed or on the back lug I'd think, not sure gripping a metal cap would work out well.
    I still like Kyle's solution tho, or mine!
  20. #15
    Apr 2008
    1,167
    242
    454
    Quote Originally Posted by Terry Keeley View Post
    Ø7.24mm x 0.5mm, at least that is what I came up with.
    I cut a Ø0.285" x 52 as the little HLV was ready to go. Sometimes the world ain't perfect.
    I had to measure an odd shape similar to your other thread, O/T - Creating a CAD file from a simple template?, not too long ago, that is why I piped up in the other thread. I indicated the indicator tip in the spindle and it was close enough for me. Wasn't sure if I would go back in time or create a glitch in the matrix indicating an indicator, but I seem fine.
    Edit: I see Pete had the same thoughts on the thread size.
  21. #16
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    I had to measure an odd shape similar to your other thread, O/T - Creating a CAD file from a simple template?, not too long ago, that is why I piped up in the other thread. I indicated the indicator tip in the spindle and it was close enough for me. Wasn't sure if I would go back in time or create glitch in the matrix indicating an indicator, but I seem fine.
    Sweet! Thanks! Just starting to take some measurements on the template. I see you suggested this method 1st and it went right over my head.
    I might take you up on your offer if I have trouble drawing the part once I got the numbers...
  22. #17
    Aug 2003
    Eureka, CA, USA
    1,651
    353
    262
    I also had a similar requirement and made the quick/dirty adaptor in the photo. The eccentric end of the adaptor is slit for a clamp screw. There is a short, non-threaded stem on the indicator over which the adaptor fits. (The rod was drilled deep enough to accommodate the one inch of indicator travel.)
  23. Likes Terry Keeley liked this post
