Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By johnoder
Thread: movement during heat treat
    moto367 is offline Aluminum
    May 2008
    Ohio
    99
    Default movement during heat treat
    Not sure if this is the correct place to post this so please move if needed.
    I was given a 1 x 4.75 x 9.00" block that has 4 dowel holes that were machined in the mill. They want me to set it up in the edm and fix it. The dowels are 2.25" and 6.25" apart on the x & y axis. 2 of the 4 are off location by .016" and .010" in the same direction because they say it moved during heat treat. I understand things can move a little and what not but do these numbers seem a little excessive? Looks to me like someone messed up in the mill. Is there a rule of thumb on how much stuff can move based on the steel size? And, if things do move, how were things done before edm so locations were maintained? Thanks.
    johnoder's Avatar
    johnoder is offline Diamond
    Jul 2004
    Houston, TX USA
    18,441
    Jig grinder excels.
    Nothing ever moved that much in heat treat if it were that size. (Caused by operator, not heat treat department)
    Zahnrad Kopf and TDegenhart like this.
    HuFlungDung is offline Diamond
    Jan 2005
    Canada
    6,088
    What material was used? What kind of heat treatment and quench was used? Does the block appear to have warped faces? Was the part machined in a manual mill?
    Can you split the error among all the holes, instead of picking one at random as your zero datum?
    JRIowa's Avatar
    JRIowa is offline Diamond
    May 2003
    Marshalltown, Iowa, USA
    5,689
    L-6 is about as bad as anything for movement. It grows by about 0.001"/inch.
    Somebody missed some hole locations.
    We didn't have a jig grinder. Used a sinker EDM with a 3R orbitor.
    JR
    Zahnrad Kopf's Avatar
    Zahnrad Kopf is offline Stainless
    Apr 2010
    Tropical Milwaukee, WI
    1,278
    Quote Originally Posted by johnoder View Post
    +1 ... ... ...
