I am looking to purchase a Hurco 5M mill, and its too tall to come through the door, so looking at options where to separate it.
I need to either remove the Spindle Motor, Z axis Servo, and then the Variable Drive, or just unbolt the whole over arm and remove everything one shot.
Removing the whole over arm, is the least work, I just worry about lifting it, and the CG being off. Also is there a chance when I bolt it back on the spindle will not be 100% trammed? Anyone know if there is anywhere to adjust it afterwards? Is there any adjustment at the actual spindle ?
How about removing the Motor, Z Axis drive, and Vari drive, is that fairly straightforward ?
(picture is not actual machine)
