Weight is about 3900lbs or 1775kg per the manuals.
They can be moved on a pallet jack if on hard flooring. slinging diagram is in the manual. I created pdf versions of the manuals I got with my machine including the brochure, the electrical manual, preliminary instruction manual (has the picture indicating how to sling), and the service manual, also have the operators manual but did not create a pdf as the systems at work seemed to have difficulty with a ~40 page manual.
Send me your email and I'll send the pdf's some are relatively large in the range of 5 to 6 mb. Probably should put them online somewhere given that SIP is no more.
What tooling did you get??? That is a key item.
Strapped mine down to a metal tilt trailer and moved it about 80 mi.
Paul
