moving vert. compressor, lying down on its side?
Results 1 to 9 of 9
    Aug 2007
    Great Lakes USA
    168
    15
    22
    Post
    hey all, sorry for the "you should know that already" question, but i just bought a 60 gallon vertical air compressor from someone, and wanted to know if it'd be okay to lay on it's side for transport? it is oil lubricated.
    i have access to a suburban and a couple friends to move it this weekend, but it won't fit in standing up. it's about a 40 mile commute, weighs approx. 300 lbs.
    i used the search function, but could not find anything related to this.
    thanks you.
    May 2007
    cincinnati ohio
    83
    Post
    Drain the crankcase otherwise should be fine
    Jun 2004
    titusville fl. usa
    3,619
    14
    Post
    put new fresh oil back in it when you get it setup and i would let it sit overnight just to let any residual oil drain back into the crankcase...jim
    Sep 2006
    SE PA, Philly
    5,125
    923
    1592
    Post
    Laying it down makes a lot of sense to me.
    It will work much better if you follow the draining/refilling instructions above, and it makes it to the destination still fastened to the truck with the dirty side of the truck down, than if you try to strap it into the bed with the compressor and center of gravity 9 feet above the ground, and it spends part of the trip cartwheeling down the freeway sans truck (or worse, with truck).
    I would put down some 4x4s with a band-saw-cut radius to support the thing, and MAKE SURE that the thing is really, truly, absolutely anchored. Don't want the compressor/motor to join you in the cab, especially if he brings his friends broken glass and twisted metal shards.
    The remains of a $100K mass spec that slid the length and smashed into the front wall of the trailer are worth their weight in scrap metal.
    Good luck,
    Jim
    Oct 2003
    Bonners Ferry, Id
    2,875
    572
    372
    Post
    He did say "Suburban" which means the only way it will fit is prone,
    It will already be inside, with a seat back as the protection from said compressor.
    Aug 2007
    Great Lakes USA
    168
    15
    22
    Post
    thanks for the advice everybody, and yeah, what kenh said.
    i made what essentially is a truck bed sized short pallet tonight, and am going to block the compressor in between the back seat and the wood.
    and if i do drain the oil out before i move it, the crankcase is the body that the pistons are in, right? is there typically an oil pan or something like that, or is there just a drain plug i can open and then tip the thing over to drain it?
    thanks again.
    Apr 2007
    Hertfordshire, England
    1,223
    322
    54
    Post
    Usually just a plug at the bottom corner of the crankcase, just unscrew and drain it into a tray or bottle.
    Fill with fresh when its installed and youre away.
    Good luck
    Dave
    Jul 2005
    Chevy Chase, MD
    1,057
    76
    86
    Post
    I moved a 60 gallon Speedaire in the reclining position. I didn't have time or tools to drain it, so I put it pulley-up, strapped it down, and brought it home. I let it sit for a day or so, then spun the compressor a few turns manually to be sure the bores weren't full of oil before I fired it up. It was fine.
    That said, it's a good excuse for an oil change now, so drain it if you can. If you can't though, it's not the end of the world.
    Sep 2006
    Sacramento County, California
    3,288
    1792
    944
    Post
    I brought my 80 gallon vertical air compressor home in the bed of a pickup truck lying down about 12 years ago. It had no oil in it at the time. No harm was done at all. I just put oil in it when I got it installed and it's been running ever since.
    Not to worry!
