Page 1 of 4 123 ... LastLast
Results 1 to 20 of 71
Like Tree22Likes
Thread: Multi-start Threading?
    Putch's Avatar
    Putch is online now Hot Rolled
    Nov 2011
    Butler, PA
    539
    Default Multi-start Threading?
    I was just thinking about cutting a multi-start thread for the first time and was wondering if a single start nut would work on one? From what I understand, a multi start thread's purpose is for speed and they have greater cross-sectional strength than a normal thread. Can a single start nut start on each of the 4 leads on a 4-start thread? I guess I'll figure it out once I start cutting, but thought some of you guys would have some useful info on the topic. Thanks
    locoguy is offline Hot Rolled
    Oct 2004
    SE Ohio
    634
    Never have I cut one, but a single thread nut will not work on a multiple start thread.
    oldbrock likes this.
    67Cuda's Avatar
    67Cuda is offline Stainless
    Oct 2008
    West Coast, CA
    1,821
    Quote Originally Posted by Putch View Post
    Hmm, no.
    Sometimes machining requires visualization, just think about about what you posted.
    Tom
    willbird is offline Banned
    Jul 2005
    North(very) West(very) Ohio...near exit 13 on OH turnpike
    3,714
    You COULD make a single start nut that would go on say a 2 lead thread two different ways, but it would have a very funny looking thread sort of like this
    /\__/\__/\
    May 2010
    Kolding Denmark
    7,152
    Quote Originally Posted by willbird View Post
    /\__/\__/\
    I believe I've seen that done but can't remember where or why.
    gorrilla is offline Stainless
    May 2007
    Central Texas, West and North of Austin
    1,042
    The short answer is no.
    The long answer involves why "No". The multi-start thread is a faster pitch, as in the helix around the part is at a steeper angle than a single start thread. The "nut" on a multi start thread traverses the "bolt" at a faster rate, longitudenally, than the equivalent single start thread. Another way of putting it, if you count the threads on a multi-start thread, and then on a single start thread of the same threads per inch count, the multi start will thread into its nut by the multiple of the thread faster than the single part. An 8TPI double start will thread into it's nut twice as fast as a single start 8TPI. At first glance, they LOOK the same, but if you look at the helix, and the gap between threads of the same lead, they are drastically different.
    I used to cut a 5 lead buttress thread in a down-hole oilfield tool. Watching that SL7 Mori Seiki run that explained it all better than a book full of words.
    Jul 2005
    3,714
    Quote Originally Posted by Gordon B. Clarke View Post
    Pop bottle screw on caps ?? maybe not a multi lead, but a thread made in segments so the plastic injection die can make it ? Looks sort of like a "skip tooth" tap in some cases.
    swarf_rat is offline Stainless
    Feb 2004
    Napa, CA
    1,764
    It seems to me that you could make a multistart thread that would work with a standard nut. I'm not sure it has any utility, but just for the pedantic exercise: why couldn't you take a normal threaded stud, cut a new thread start halving the existing threads at the same pitch? The thread form wouldn't be as strong (half as high). But a standard nut would go on perfectly engaging the available thread depth, and further it would start on either of the two thread flights. If measured with a thread gage it would look like double the TPI, but the pitch would be the same. It's kind of like Willbird suggested, except changing the stud instead of the nut.
    wlbrown is offline Hot Rolled
    Nov 2002
    wright city, mo.
    586
    HELLO,
    on multistart threads, the pitch is two time faster.this is on a
    2 start thread.if the pitch is 11 tpi, then the gear box must be
    set at 5 1/2 tpi. one some machines to cut the thread you proceed
    just like normal, but the thread dial is the main function.one the first pass,
    you close on number1, and on the second pass you close on number 3.this
    is on a dial that has 4 numbers on it.this puts the second cut in the center
    of the first cut. this may not work
    on all machines. you have to try it to make sure it works. this works
    very well on manarch 10EE machines.
    good luck to all.
    wlbrown
    Mike C. and thebigron like this.
    Toms Wheels's Avatar
    Toms Wheels is offline Titanium
    Dec 2005
    Jersey Shore
    2,976
    Wilbrown you are incorrect in your thread dial suggestion. There would be only a very small # of threads that could be split with the threading dial. If cutting a 16tpi double start thread, no matter where on the dial you engaged the half nuts you will end up cutting the same path each time. The cutting tool would need to be offset .0625" in the example given to cut the second thread.
    No way would a single start nut thread on a double start thread. A double start 16, has the thread depth of a 16 pitch thread, and the advance of a 8 tpi thread. So the minor diameter of an 8 pitch nut is to small to fit the thread depth of a 16 pitch, and a 16 pitch nut has the wrong helix angle to fit the 8 tpi angle.
    9100 and James H Clark like this.
  11. #11
    BR3
    BR3 is offline Aluminum
    Apr 2011
    NC, USA
    96
    As I think about it...you could cut one thread the same as one of the multi start threads and then continue to cut all other material that was not part of the single thread form away. The only practical reason I can see for doing this much work would be for a gage to check each start individually. That would only work after the mating part was finished though. Seems kind of pointless to me. Or you could use it as a teaching aid.
  12. #12
    Feb 2004
    Napa, CA
    1,764
    Quote Originally Posted by Toms Wheels View Post
    I'm not suggesting that a "standard" double start would fit a standard nut, just that one could be cut that would fit, and properly too, and would start on both flights - unless I am missing something fundamental. Might be hard to cut on a Monarch 10EE, but I think pretty easy on my CNC!
  13. #13
    May 2010
    Kolding Denmark
    7,152
    You might just be right
  14. #14
    May 2010
    Kolding Denmark
    7,152
  15. #15
    Stuart Caruk is offline Hot Rolled
    Feb 2007
    Ridgefield, WA
    829
    We do hundreds of different varieties of multi start threads a month for very specific applications. The most common one is a fast acting pilot valve. If you measure the thread pitch with a thread pitch guage it would measure as a 24 TPI thread.
    In reality, it is 3, 8 pitch threads stacked 120 degrees apart. It's a triple start 8 pitch thread. If you try to thread on a standard 8 pitch or 24 pitch nut, it will bind up. If you thread on the matching triple start nut. it will travel an inch in 8 turns. It's just that there are 3 sets of threads sharing the load, so you can use shallower threads.
    Multi start threads are common in submarines, space products, and certain military products (think explosive decoupling bolts). On a CNC lathe they are simple to turn, for a triple start, you simple adjust the start point 1/3rd of a pitch away from the origin. Extend the thread so they all match if you need to. On a mill you program the same thread, but start it 120 degrees from the initial and subsequent start.
    It's a hard concept to wrap your head around. I remmeber my first double start years ago. I simply didn't believe it was possible. So I made a test part. Then it was super clear. It's a great conversation piece in your shop, because few other machinists have ever heard of, much less seen a multi start thread.
    stevenacarter77 likes this.
  16. #16
    Mike C. is offline Diamond
    Nov 2004
    Birmingham, AL
    9,822
    Old school way to do a multi start thread is to run the work between centers and put the tail of the drive dog against the jaw of a four jaw chuck (for 2 and four lead threads) or a three jaw for three start threads. You can use faceplate slots, make a disc and drill holes in it, slot it, whatever to provide an index. Some lathes, specifically the Hendey T&G, had an index system built into the spindle to allow multi starts.
    stevenacarter77 and Abom79 like this.
  17. #17
    Mydrrin is offline Cast Iron
    Jan 2012
    Canada, Edmonton
    447
    2 start threads have double the feed rate of a 1 start thread. The feed on a 4 TPI - 2 start thread would be 0.5" / rev at 90 deg separation. So no you cannot, you need to make another gauge. You can use wires.
  18. #18
    Putch's Avatar
    Nov 2011
    Butler, PA
    539
    Quote Originally Posted by wlbrown View Post
    HELLO,
    good luck to all.
    wlbrown
    exactly what I was thinking - 2 times faster or else the pitches would run over themselves. Didn't really have a use for this but my mind's always going and figured I'd cut one so I have a leg up on those who haven't.
    jdj likes this.
  19. #19
    4GSR's Avatar
    4GSR is offline Titanium
    Jan 2005
    Victoria, Texas, USA
    2,202
    Putch,
    Some of them trepanners down at Boring Specialites had double pitch lead screws on them, at least when I was there. I know, I threaded a couple of brass nuts for them!
    Ken
  20. #20
    johnoder's Avatar
    johnoder is online now Diamond
    Jul 2004
    Houston, TX USA
    18,482
    Ferguson, a UK gent of old, had a breech loading flintlock rifle, the breech of which was a multi start thread. This threaded plug was vertical, and attached to the trigger guard. One turn of the trigger guard would drop the plug sufficiently to open the breech for loading ball and then powder. I can see making the plug not much of a problem, but the mating female hole - supposedly somewhat gas tight - must of been a pain. George Wilson can tell about it better.
    When in the apprenticeship, back in the sixties in the Connecticut days, I tried for the plug on the loose change 13" X 5 foot South Bend in my basement. 9 starts on a 7/8" diameter with 1" lead.
    It looked a little raggedy.
    Mike C. and Putch like this.
