Are my lathe's spindle bearings out of whack?
Results 1 to 15 of 15
    Feb 2018
    Utah
    6
    Default Are my lathe's spindle bearings out of whack?
    Hello all,
    I've recently acquired a Logan 1825 that was an old shop class lathe and has taken some love to get cleaned up and running. I noticed that I was getting some wobble on my workpiece so I've been trying to track down the cause. After putting my dial indicator on the outside of my chuck I found that it wobbles about 4 thou. I pulled it off and put my dial on the spindle just above the treads where it's flat and it's off about 0.6 - 0.8 thou.
    Is this enough of a misalignment that I should be concerned?
    Would this be a bearing issue? Damaged spindle?
    How do I tell?
    I'm still climbing that learning curve so drawing it out in crayon is much appreciated.
    Thank you!
    Sep 2015
    160
    12
    63
    Put the chuck back on and set up a dial indicator on top of it. Then using a 2x4, gently pry up on the chuck to see if the indicator reads it moving up and down. You can also check the end-play of the spindle this way. Lateral and/or axial movement of the spindle typically indicates bearing failure.
    Mar 2009
    3,748
    72
    614
    If you making table legs out of wood then it might be acceptable. Otherwise forget it. "oh my poor bearings".
    For a reference, a Hardinge lathe runout is +/-.000025.
    Aug 2003
    Eureka, CA, USA
    1,629
    343
    245
    Personally, I wouldn't give up on the old Logan without first adjusting the spindle bearings. (A Logan can't be a Hardinge even if touched by a fairy wand at midnight, so don't presume that .000025 runout is even remotely possible for your lathe. Quadruple that and you'll be in the ball park.)
    Adjustment procedures differ depending on the type of bearings your machine has but there's a fifty-fifty chance that you can improve that runout with a bit of work, given the lathe's history.
    Do some internet research on adjustment procedures before diving into this, however. It's ALWAYS possible to make a poor situation worse !
    P.S. When measuring spindle runout, the usual practice is to measure the internal morse taper. Make sure that the taper is clean and free of dings.
    May 2003
    Iowa
    9,815
    2991
    3660
    First of all, I'm lefthanded also
    2nd What are you using for an indicator? If you don't have a "tenths" indicator, you're probably just seeing dings in the spindle.
    3rd. 4 thou on the OD of a chuck means very little. It's the OD of the chuck and nothing more. In fact, that's really pretty close.
    4th. You "newbies" tend to think you need to check everything before making any chips. Put a piece of steel in the chuck and turn the diameter down. If you can't take a 0.030" DOC without a bunch of chatter, then start looking for stuff.
    Don't look for problems where there are probably none.
    JR
  6. Likes tdmidget, JohnEvans liked this post
    Aug 2003
    Eureka, CA, USA
    1,629
    343
    245
    Quote Originally Posted by IAmTheSouthpaw View Post
    ...I noticed that I was getting some wobble on my workpiece...
    I think that he's suggesting that there is a problem (although he wasn't very specific) ?
    Feb 2018
    Utah
    6
    Quote Originally Posted by Spruewell View Post
    I did this and with medium pressure on 3 foot 2x4 it moves about 3-4 thou. but returned to almost the same location. I rotated over to the "low" spot and gave a little more pressure. Now it's only out about 2 thou. There is no obvious lateral movement.
    Should I keep prying with the 2x4 and try to get it close?
    Is this an indication that the spindle is damaged?
    What would you do next?
    Thanks Spruewell
  9. #8
    Jul 2003
    savannah, jaw-ja
    1,513
    797
    302
    Then there's the most likely clapped out old three jaw that's been crashed a few times in shop class holding the work that is "wobbling".
    Edit - the 2x4 test is just to see how much movement there is, not to bend anything! Note the word "gently" before the word "pry".
  10. Likes dalmatiangirl61 liked this post
  11. #9
    Feb 2018
    Utah
    6
    There is a bit of surface rust on the inside of the taper. Would a brass brush be too aggressive? Would a brass brush be too aggressive on the ways?
    I'll clean out the taper and measure again.
    Thanks Randyc
  12. #10
    Feb 2018
    Utah
    6
    Quote Originally Posted by JRIowa View Post
    JR
    1) Being left handed is hard, we're the only people in our right minds.
    2) Starrett 656, it does have a "tenths" indicator.
    3) I was thinking that it may just be the chuck, but it's nice to be reassured.
    4) I love this lathe. It has also been sitting for a good long while. I had to push through a solid layer of hardened crem in the apron plug.
    I've turned some aluminum which went pretty nicely, but later noticed the wobble and started hunting. If you think that it's pretty close then I may just be hunting snipes.
    Thanks JRIowa
  13. #11
    Feb 2018
    Utah
    6
    Quote Originally Posted by Rudd View Post
    Good call. That's what I thought but just wanted to double check before I did any real damage.
    You are absolutely correct in assuming the chuck has been hit.
    There is obvious damage on the compound rest where it's been run into the chuck by a teacher (students wouldn't dare!). The chuck has been replaced but the strike may have thrown the bearings out of alignment?
    In hindsight I should have included this little detail in the original post, my bad.
    Thanks Rudd
  14. #12
    Feb 2018
    Utah
    6
    Quote Originally Posted by randyc View Post
    I cleaned out the taper and measured the runout again. Luckily the hand on my dial indicator landed right on a tick mark because I could barely tell when it moved when I turned the spindle. I'm going to assume this is good
    Thanks Randyc
  15. #13
    Jan 2011
    BFE Nevada/San Marcos Tx
    95
    81
    45
    Coming from a school, anything is possible, even a bent spindle. Yes a brass brush is fine for cleaning out spindle, and on ways.
  16. #14
    Aug 2003
    New York
    88
    10
    Iamthe southpaw,
    Your indicator (starrett 656) is graduated in thousandths or .001" increments. Generally when someone here mentions "tenths" they are referring to tenthousandths or .0001" and not .01" which would be 1/10 of an inch. If your lathe has tapered roller bearings in the headstock you should be able to tighten them a little to reduce that deflection with the 2 x 4. Light pressure, with the 2 by is important, remember that. Do not over tighten the bearings. Should you adjust the bearings be sure they are lubricated well and watch for excessive heat. Enjoy your toy. Oh yeah, I'm in my right mind as well...
  17. #15
    May 2003
    Iowa
    9,815
    2991
    3660
    1) 2) Starrett 656, it does have a "tenths" indicator.
    The 656 is a travel indicator. Save up some money and get an Interapid 312-B
    http://www.metronprecision.com/Merch...jpgammaadj.jpg
    60 thousands travel, shock resistant, and auto reverse.
    OK, back to the lathe. Mos used 3 jaw chucks are probably junk by the time your get them. New, they usually aren't much better. The one I have and rarely use probably has 0.003" runout with the jaws re-cut. If you want accuracy, get a 4-jaw chuck. So many guys are scared of them because they really don't know how to use them. If you use one enough, you can put a piece of round stock in and have running within 0.001" in less than 10 minutes.
    JR
