mystery item; what might these tools be for?
Results 1 to 13 of 13
    Aug 2005
    Toronto
    4,935
    2581
    2799
    Default mystery item; what might these tools be for?
    cryptic headings are frowned on, but its a cryptic device. These shop made items were done as a set, with standard fractional dimensions stamped in them. thing is, none of their dimensions remotely equates to the stamped number
    The pointy end is on a light spring; finger pressure easily pushes it inside the body. There is no mechanism for an automatic punch
    They came out of a tool and die makers box
    any ideas? thanks
    Jan 2006
    maryland
    2,278
    1408
    393
    They look like shop-made tap guides for manually tapping holes in a bridgeport-type setup when you need the threads dead-nuts perpendicular
    May 2009
    wis usa
    44
    33
    Default mystery tools
    2nd what Ironhead said . Spring loaded center for hand tapping on a machine.
    May 2002
    South Central PA
    12,438
    1507
    2622
    If they are, it's interesting that he made so many in small increments of diameter. One would normally be enough, unless he was trying to avoid changing collets. And why would you be using 1/2 and 5/8 etc. collets when drilling tap holes?
    Aug 2005
    Toronto
    4,935
    2581
    2799
    yeah, i don't think that's it because the diameters at the end don't match up with the stamped number, ie there is not a 5/8 dia on the 5/8 one..
    Apr 2006
    Fort Worth, TX
    1,303
    25
    26
    Would the marked sizes correspond with the diameter of some point (most likely mid) along the tapered section?
    They could be alignment tools of some sort, used maybe to center an oversize hole in a thin plate or flange with another feature.
    Feb 2004
    Metuchen, NJ, USA
    5,366
    3989
    798
    Question 1: Is the chamfer angle at the business end the same as the standard countersink screw head angle?
    Question 2: Does the point disappear into the body when retracted, or can you made a punchmark by using the body like a slide hammer?
    On Edit: Does the diameter of the business end correspond to the diameter of a countersunk screw of the diameter marked on the body? i.e. Is the diameter of the business end of the punch marked "1/2" equal to the diameter of a countersunk head on a 1/2" screw???
    JRR
    Aug 2009
    Royersford PA USA
    276
    Is the diameter of the flat end the size of the drill for a taped hole of the stamped size? Could you drill the hole and put one in without changing collets?
    Jan 2006
    Angier, North Carolina
    2,219
    675
    696
    Is it correct to assume that the set screw on the side will lock the point in place?
    Feb 2010
    Temple, Texas
    21
    Default I think those are transfer punches
    They are obviously knurled to be hand held, and if my eyes are correct it appears that two have slight mushrooms on the head, apparently from hammer blows.
    They apparently have replacable points.
    JMHO
  11. #11
    Nov 2004
    Viborg, Denmark, Europe
    855
    659
    453
    Maybe they came out of this place?
    START- Hufnagel Werkzeuge
    Best regards
    Søren
  12. #12
    Jul 2008
    People's Democratic Republic of Louisiana
    2,557
    562
    266
    The ends where the retracting points appear to be chamfered, like a cutting edge. Maybe they are to precisely locate a hole to be punched in gasket material, or the like. Locate the center of the intended gasket hole, push down on the tool, retracting the pointed piece, strike the other end with a hammer.
  13. #13
    Aug 2005
    Toronto
    4,935
    2581
    2799
    thanks for all the ideas, I think SouthBend nailed it.... I checked the very short taper neat the point and it seems like its 82 and the short taper section would seem to fit a counter sunk cone relating to the stamped number....and the set screw does lock the point. I'm pretty sure they aren't factory to Hufnagels, crooked stamping + there's other stuff labled Haufnagel...he was a machinist or T&D maker who gave or sold the stuff to the estate i got it from.
    countersunk transfer punches....for thin, countersunk pieces
    thanks all for the help!
