Narrow fan belt for Sears drill press
Results 1 to 19 of 19
    Oct 2003
    Clio MI.,USA
    888
    Post
    Does anyone know of a supplier, other than Sears, for those narrow belts? They are about 1/8" wide.-Thanks, Jerald Ware
    Nov 2004
    Islip, NY
    513
    Post
    I threw out my belt with the machine on it a long time ago
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,390
    33
    712
    Post
    try sewing machine belts , or o-rings instead.
    Dec 2004
    Falls Church, VA
    1,225
    Post
    I got my belts from Sears, about 4 years ago. Haven't tried them for parts since.
    Thermo1
    Sep 2004
    El Dorado, Ar. USA
    62
    Post
    Some old Grainger drill presses (mine included) used a similar belt. This press still works well with the original belt (30+ yrs. old w/6 inch stroke) If memory serves it was made by Gates. Try an industrial supplier or Grainger.
    Apr 2005
    Benton, IL USA
    4,567
    7
    44
    Post
    Would the Sears part number help? I can probably find the manual for my Craftsman DP that uses the same (or similar) belt.
    Barry Milton
    Dec 2000
    Bremerton WA USA
    10,633
    40
    4048
    Post
    Gates still sells them. The 8 speed Sears drill press that uses them is a dandy and has a long quill travel. I wish I could find one in good shape.
    This is not a weenie belt but a strong high tech 60 degree included angle siped V belt. Check wout your local belt supplier. Take the old belt for a sample with a stout string representing the length needed over the pulleys.
    Oct 2004
    lou. ky
    168
    9
    Post
    Oct 2004
    lou. ky
    168
    9
    Post
    i got mine in 1977 from sears they came without a motor. i bought new belts just in case. i was cleaning out cabinet thursday and found new belt still in package with part number on it. i have only used mine for pilot holes still looks like new. jon
    Jul 2006
    Va.
    153
    Post
    I replaced mine about two months ago. The local Sears parts/repair store had them in stock. It was 10 bucks and change.
    Lee
  11. #11
    Jun 2003
    Thomasville, GA
    1,562
    6
    Post
    "The 8 speed Sears drill press that uses them is a dandy and has a long quill travel. I wish I could find one in good shape."
    I agree. Mine has taken all manner of abuse and performed flawlessly for 24 years.
    The one mod I made was the addition of a footswitch in parallel with the one on the head. That really makes it much easier to use. [img]smile.gif[/img]
    Roger
  12. #12
    Apr 2005
    Benton, IL USA
    4,567
    7
    44
    Post
    I certainly agree with you, Forrest
    These were made IIRC by Atlas. Mine was purchased new in 1982 or 1983. A friend had an Atlas catalog that showed an identical model. It continues to amaze me that the tiny belt will drive a 1" twist drill through 1" plate.
    The mill gets much more use, but there are jobs that are much more easily done on that drill. Mine has the heavy T-slot table. A 4" milling vise does most workholding.
    Sears sold a crank & chain table lifter. It seemed expensive at the time but turned out to be money well spent.
    Barry Milton
  13. #13
    Sep 2005
    Indiana, USA
    2,868
    53
    Post
    Thin may be in:
    But FAT is where it's at:
  14. #14
    Nov 2006
    Houston, TX.
    447
    49
    25
    Post
    The number on my belt looks to be 5MR1150, I got mine in 1981 and every bearing in it sounded like they had been pounded in by the outside race, they howled, as did the spindle pulley on 8000 rpm. I immediately replaced all the bearings and balanced the pulley. I've done absolutely nothing to it since. It the skinny belt does slip with big bits though.
  15. #15
    Dec 2004
    Falls Church, VA
    1,225
    Post
    I bought mine new in 1976. The belt drive still works well, but the quill retract is getting stiff. I have lost the original manual, and have to get another from Sears,as there is no way I am going to tinker with that big spring loaded retract mechanism without a manual.
    Rest of the drill press has worked fine. The 8 speed design is rather elegant works well for me. I have used the 8000 rpm speed on numerous occasions, even using the drill press running at 8000 rpm as a wood shaper.
    Thermo1
    Thermo1
  16. #16
    Dec 2004
    Falls Church, VA
    1,225
    Post
    One other point. For general use, I use the Jacobs chuck that came with it. For more pecision, I replace the Jacobs chuck with a Albrecht style (made by Jacobs) that fits the #33 Jacobs taper on the spinde. Improves the accuracy and reduces drill runout a bit.
    A good chuck seems to improve the accuracy of even this mid priced drill press.
    Thermo1
  17. #17
    Feb 2003
    Southeastern Connecticut
    739
    11
    Post
    I can't ever recall using anything but the lowest three speeds. What's the point of of all the higher speeds? (Especially the really high speeds)
    My drillpress is the "Commercial" version with double slotted table and provision for a tilting table on the backside.
    Great machine with one major flaw. No table lift.
    Bought new around 1976 with one spare belt which is still in it's package.
  18. #18
    Nov 2006
    Houston, TX.
    447
    49
    25
    Post
    Thermo1,
    The way to remove the spindle and unwind the spring is rather elegant in it's simplicity, grab the quill feed handle and draw it away from the body of the machine, the quill will drop right out in your left hand if you first remove the depth limit off the rod. Then just let the spring unwind carefully. Completely unwound I think the Spring unhooks itself from the casting. This is also the way to set the handles just where you want them, drawing it out and re indexing the gear.
  19. #19
    Jul 2004
    Asheville NC USA
    8,948
    3393
    2978
    Post
    The Millrite mill we've got in the shop uses one of those narrow belts. My dad bought the mill new in '69 or '70 and the belt's never been replaced. Probably the most durable V-belt I've ever seen.
