Clive603
Titanium
- Aug 2, 2008
- Sussex, England
So I've been using the same import 6" jaw cross vice as the standard fit work holding device on various pillar drills for maybe 25 - 30 years. Being an early one it's a bit better built than the current cheapies. Probably more aimed at the low end pro user than current home shop target ones. Sticker price then was maybe half as much again as sticker / E-Bay prices now. Objectively less than ideal but with a set of prismatic jaws, one horizontal Vee & 3 vertical ones, it gets far enough up the "It'll do I s'pose" scale that I've lived with it.
For the last few years its sat on Fredr'k Pollard 15 AY drill with a gear driven, 9 speed, 3 MT spindle. The vice can definitely struggle with larger MT3 drills up t'spout. I don't think it will break but it can wobble in moderately alarming manner. One things for sure the 15 AY won't stall out if something hangs up! So as a suitable, more robust X-Y table has resurfaced after long term (resting!) loan. Table has space for something around 8 x 12 overall. I figure its time to fit something a bit more appropriate on it and accept a re-homing offer on the old one.
Trouble is I've not got a clue as to what would be an appropriate vice. The only other drill vice I've used is a Nippy. Good but designed small. I guess 6" wide jaws and a holding capacity in 6" to 10" range would work. Most of what comes up when looking for drill vices are of the scary flimsy / you cannot be serious variety with long slender clamp screws and light almost un-supported jaws. Found a few heavy duty ones which seem to be milling vice style with open centres and shorter moving jaw blocks. Usually no or not heard of name and moderately expensive for what they are. Appears to be little advantage over getting a used decent brand milling vice off E-Bay for half the price and living with the battle scars. Long moving jaw block does mean that 6" x 6" is about the limit size wise for milling vice.
Rack style vices are attractive as having a short stiff screw and an compact moving jaw set-up giving larger length capacity relative to base size. Lots less winding when going from short job to long one too which is nice. Short wide ones are like hens teeth tho'. Usually only 3" or 4" wide jaws in the length I can accommodate.
Maybe I should just bite the bullet and build something. I found a design from Popular Mechanics for a planer vice that could be a basis http://www.galleyrack.com/images/ar...922-03-p462-pdf505-adjustable-planer-vise.pdf . Similar to rack style but with a rectangular key instead of the rack and a fully floating L shaped moving jaw held down by an opposite hand L block carrying the pusher screw. Not sure about the fully floating jaw. Or I could really rev-up the creativity neutrons and do something "inspired by Chick". Fundamentally the Chick is a rack style after all and built-up screw'n glue construction to an accuracy sufficient for a drill vice looks do-able. I'm into making jaws anyway whatever I get.
Or does the team think its all going to be too much trouble for insufficient real gain unless I splash out on one of the CNC vices, which isn't gonna happen.
Thanks.
Clive
Thanks.
Clive
