Pete F
Titanium
- Jul 30, 2008
- Sydney, Australia
Can anyone who uses thermal drilling advise what they're using for a lubricant on the drills? I've been using Tapmatic lubes (both aluminium and conventional) on the respective materials, but suspect they're not the ideal choice. It would also appear that just a tiny amount of lube is the required amount, and more isn't better.
I know Flowdrill offer lubricant, but I was hoping to find an alternative in normal cutting oils, conventional oils, EP grease, etc etc. I was considering trying something like this S 84 | EP 3.5 Heavy Duty Tapping Compound | For Sale Sydney Brisbane Melbourne Perth | Buy Workshop Equipment & Machinery online at machineryhouse.com.au
On a second point, is there any value in drilling small pilot holes with a standard drill before following with a thermal drill? It seems the initial part is what takes the most effort and I wonder if the holes can be made to start and flow easier with a pilot. That could also locate the thermal drill as a secondary function. I haven't ever tried with a pilot, and don't want to start destroying thermal drills if having an existing hole will just cause the thermal drill to grab.
Thanks.
Thanks.
