Need DoAll Bandsaw Schematic
Results 1 to 10 of 10
    Jan 2003
    Temple, Texas
    2,283
    12
    207
    Default Need DoAll Bandsaw Schematic
    I have a DoAll 1612-0 bandsaw with a DBW-15 Blade Welder. The machine is set up for 440 and I want to change it to 220. I would like to have an electrical schematic. I have the manual and parts list - they are available on the DoAll site. DoAll does not post the electrical diagram. The motor is a dual voltage motor, so I know I can do that. The welder transformer appears to be dual voltage as well. I can probably figure the whole thing out, but a schematic would make it easier.
    Jul 2004
    Houston, TX USA
    27,098
    PM me Bruce with your email and I'll send the scan of that page. All the DBW-15s run on 220 single phase by the way.
    Probably will be an issue of reconnecting motor for lower voltage and correcting thermal over loads in mag starter for the double size amps.
    John Oder
    Jan 2003
    Temple, Texas
    2,283
    12
    207
    John-
    Thanks for the welder schematic. I removed one of the heaters from the starter and made some phone calls. I discovered that the heaters in place are rated for the current that corresponds to 220V operation. Looks like this machine started out in life as a 220V machine and was converted to 440V without a heater change.
    Jul 2008
    Greenbelt,Md
    Default DoAll Schematic
    Hi John,
    I have the DoAll 1612U. Is there any chance i can those schematics from you also?
    I need the schematics for the machine too, if you have any sources for that.
    Much appreciated
    Ken Cory([email protected])
    Quote Originally Posted by johnoder View Post
    John Oder
    Jul 2004
    Houston, TX USA
    27,098
    I will do this tonight at home Ken
    Scan sent 1645 CSDST
    Mar 2009
    New England
    6
    Default Doall 1612 schematic
    Quote Originally Posted by Bruce Griffing View Post
    Did you ever find a schematic for the saw and welder? If so can you pdf it to me?
    Regards
    [email protected]
    Mar 2009
    New England
    6
    I am in need of a wiring diagram for a Doall 1612-0 with blade welder. Any chance you can help me?
    Regards
    Nelson
    [email protected]
    Jul 2004
    Houston, TX USA
    27,098
    Sent on down the cyber road 8:57 PM CST
    Quote Originally Posted by nelsonk11 View Post
    Regards
    Nelson
    [email protected]
    Mar 2017
    ALAND ISLANDS
    I also have the 1612-0 saw with blade welder . Would it be possible to get the electrical schematics for both?
    Sent from my SM-T550 using Tapatalk
    Jul 2004
    Houston, TX USA
    27,098
    Read first line in Post #2 and do what it says if you don't want to post your email address here as folks in above posts have done
    "PM" is Private Message
    As noted above the schematic is for DBW-15
    Quote Originally Posted by roncoffey84 View Post
