Forestgnome
Stainless
- Aug 2, 2008
- Californeeeah
I'm dealing with a recurring problem of broken hardened screws in a product my company repairs. The screw is used as a shaft for a clamping roller, and has a shoulder that extends down into the aluminum frame. At the end of the shoulder the screw is threaded M4. These screws are specified to be hardened to 53-60 HRC. The first one I extracted okay. I used a 1/16" carbide drill and my homebrew 4-sided extractor. I have been unable to get the next two out. My extractor is a broken tap ground to four sides, but the hardened screws just bite the edges down so it rounds off. I can get almost enough torque to break the extractor. These are specified to be installed using Loctite 222E (I've been unable to find specs on this, only on 222). I suspect maybe our customer has re-installed these with some really strong thread locker, as these won't budge, even with heat. I was thinking of just drilling the rest of the screws out, but the carbide drills I found are specified to drill up to 45HRC. I could just use inserts since the frame is aluminum.
Any suggestions?
Any suggestions?
