CountryBoy19
Stainless
- Aug 14, 2012
- Bedford, IN
Working on some odd stuff. I think the screws are proprietary, I just need a few replacements. Due to the small size it's hard to determine what the thread specs are for sure but here is what I can tell you.
4-40 is too big, M3 is too big, 2-56 is too small, M2 is too small, don't have M2.5 to try but M2.5X.45 is very close to 3-56. I was able to run a 3-56 tap into the hole and it seemed to work but was a tad loose but a 3-56 screw will just barely slide through without engaging the threads.
What I am fairly certain of: this is a 56 tpi or .45mm pitch screw
M2.5 is likely too small just like 3-56, but on my tap/thread/drill chart there is a M2.6X.45 listed. I'm somewhat confident that this will give me just enough to engage the threads. This is a low-strength application where I would like to avoid re-tapping if I can (not much material left to tap out).
Problem: I can't find ANY sources for M2.60X.45 screws. Is my chart just outdated and this size isn't used anymore? Anybody know where to get some?
