Need plans for belt grinder
Results 1 to 14 of 14
    May 2007
    Northeast Atlanta, GA
    377
    121
    7
    Default Need plans for belt grinder
    I would like to build a belt sander (grinder?) with a narrow 1" or 2" wide belt. I will probably combine a disc sander and table, and enable slack or platen sanding. Belt length does not matter as I can have them made up locally. Does anyone know of any plans for something like this?
    Thanks, Greg
    Nov 2008
    Dahlonega, GA
    24
    Do a search for no weld belt sander. A guy in Minnesota sells the plans. He is also knife maker. Years ago copied a 1" Kalamazoo. Does work for light work. Deburring and lawn mower blades.
    Nov 2008
    Dahlonega, GA
    24
    To correct my post. Search for No Weld Grinder.
    Mar 2003
    Toledo Oh
    756
    Wheels and Ideas can be had here. Good people to deal with. If you do some digging around there is a lot of good info on the net. I dont see it in my book mark right now. All so there is one book out there that is fairly good. Can't lay my fingers on it Some thing like Making a knife grinder for under $50 he has wrote a couple of books on knife making. The biggest challange I had was finding a motor that I like and was big enough and pully size.
    David/toledo
    http://beaumontmetalworks.com/
    Dec 2007
    North Carolina
    832
    249
    108
    Quote Originally Posted by David/toledo View Post
    David/toledo
    A lengthy recent discussion of belt grinders and component sources is here:
    4 pages of posts starting at 11-14-2009, 08:57 AM
    http://www.practicalmachinist.com/vb...en-192396.html
    Thread subject: Belt grinders - Halfway between Burr King and
    There are many pix to get ideas from plus links to machine, components and parts suppliers.
    The Beaumont grinder is impressive - they offer a group of excellent videos showing uses for their machines.
    Jun 2008
    Logandale,Nv
    1,132
    93
    167
    Take a look at this video.
    http://www.viddler.com/explore/Rashid11/videos/1/
    Kind of slow and dry but worth it.
    Mar 2005
    Clanton Alabama
    171
    I built this one about a year ago.
    http://www.usaknifemaker.com/store/p...ges-p-723.html
    I used a 2 hp three phase motor with a vfd for variable speed. It works well. The plans are not great, but there is enough info to build a grinder. The guy has an annoying habit of referring to square tube as pipe, and then in the next sentence it is tube again.
    Forrest
    Jan 2007
    Pinckney Mi.
    3,003
    4263
    777
    so are they a belt grinder or a belt sander?
    Gw
    Dec 2009
    Vancouver, Canada
    43
    I would suggest these plans over the NWG: www.metalwebnews.com/manuals/knife-grinder.pdf
    plus, the plans are free
    good luck
    Jun 2006
    Spokane, WA
    557
    95
    Is it just me or are both those DIY grinders the most unnecessarily complicated designs have ever seen? I've looked at building them both and think if I were going to that much trouble, I'd go ahead and build a larger unit. Labor would be the same and materials very little more.
    As for the cost savings, light-duty grinders/belt sanders show up on craigslist and yard sales fairly regularly at a reasonable cost. I have two 1"x42" sanders I picked up for $25 each. I also picked up a 4"x48" edge sander for $100. The heavy-duty 6"x48" units come along less frequently, but There are two for sale locally just now.
    thnx, jack vines
  11. #11
    Dec 2007
    North Carolina
    832
    249
    108
    Quote Originally Posted by a77 View Post
    DIY 2x72 belt grinder
    This one is elegant, excellent design and very rigid with easy to install accessories including ones for knifemakers. No tubing in this one, barstock and plate. Good sharp video you can download; view with Gomplayer, use frame capture for stills of details.
  12. #12
    May 2007
    377
    121
    7
    Default Building Mike Clerc design belt grinder
    I am well into building the grinder suggested by A77 at http://www.metalwebnews.com/manuals/knife-grinder.pdf. The plans are very good. I plan to incorporate some details from the Viddler video, too. His accessory changing design is very fast, and I can get by with just one arm, especially if I use both ends. I'll put up pictures when I get it alittle further along.
    Thanks everyone for your help.
    Greg
  13. #13
    May 2007
    377
    121
    7
    I built the one drawn by Mike Clerc with some features on that Viddler video. It ended up fine, and works very well for wheel, platen, or slack sanding or grinding. The motor is a 2hp controlled by a VFD.
    Thanks all for the help.
    Greg
  14. #14
    Dec 2002
    Granville,NY,USA
    3,854
    255
    365
    Nice looking rig.
    I might just have to whip one up.
