Long Tom
Stainless
- Aug 21, 2011
- Fiddlefart, Oregon
Howdy again.
An operation I need to do in some quantity requires an 8-hole bolt pattern on about a 12" diameter. With that much lever arm acting on it, I can feel play in each position of my Hardinge copies, which work with pins dropping into holes. Looking at the Super Spacers, they appear to use notched index plates rather than holes/pins like the Hardinge.
So two questions. First, does the Super Spacer design generally have a more rigid lockup than the Hardinge design; and if so, do you have any experience positive or negative with the copies like the Phase 2 or do I need to spring for a Bison..... and second, is there a simple design for a shop-built 8-space unit that youve seen or built?
I don't need it to operate quite as fast as the Hardinge, but I do want an indexer here; if it gets into being finicky I might as well just do an X/Y extrapolation and do the holes that way. I'd really rather not as I've got a bunch of these to do.
As always, your experience and guidance is hugely appreciated. Getting tooled up for this suite of castings has been kinda epic but I'm finally to the fun part where the payoff starts in. It's ongoing work so if the solution is a $3000 Bison Super Spacer or the like then that's ok; but if I can build something, so much the better. I just can't think of a design that is tight and true in the Z axis yet easy to turn and then locks into position very securely.
On that note- the bolt hole pattern is comprised of 1/2" drilled holes in the one part and corresponding 1/2" tapped holes in the mating part. So the forces at play are not large. Material is cast aluminum. Finally, whatever I buy or make needs to be as short as possible in Z as I'm about maxed out on my mill with the Hardinge.
