Mud
- May 20, 2002
- South Central PA
I'm installing a new hydraulic accumulator on a machine. It's coming in empty because of shipping regs and I have to pressurize it. I can't find a factory spec for the nitrogen pressure. The spec from the accumulator mfg is a max of 4:1 ratio between operating pressure and preload. The pump pressure is on at 140 bar and off at 180 bar, so it will see a max of 180 bar hydraulic pressure. The accumulator is a diaphragm type and has a capacity of 1.4 liter.
If I preload it to 45 bar I will be right at the 4:1 ratio. Will this be enough to keep the diaphragm from "bottoming out" at 180 bar? How much does the nitrogen volume compress under a given hydraulic load?
Will it harm anything or reduce function by increasing the preload? Is anything gained by increasing the preload?
