Need spoolgun for my miller MIG
Results 1 to 7 of 7
    Jan 2010
    Bismarck, ND
    139
    13
    Default Need spoolgun for my miller MIG
    I have an older Millermatic 200 Mig welder. I want to be able to weld aluminum and am looking for a spoolmatic 1 spool gun that will fit the 4 pin plug on the welder. I would appreciate any links for direction to find one
    Skipd1
    Mar 2009
    Brunswick Oh USA
    4,186
    4071
    2445
    Well rats! I've got an old spoolmatic 3. Don't s'pose it'll work though. It's got 14 pins in the plug. Plus the motor is screwed up. It's your's for the asking anyway.
  3. Likes jackal liked this post
    Feb 2011
    Michigan
    457
    11
    314
    I've got a older 200 also, mine was made in 1989 and I'm using a 30a spoolgun.
    I have not used the spoolgun in a while but seem to remember having a adapter
    for it.
    If you call Miller customer service with your serial number they will tell you what works.
    As for where I watched ebay for a few months, couple of local welding stores had
    used ones ....almost the price of new.
    David
    http://www.millerwelds.com/products/...gun-chart.html
    Try this link and see if it helps
    one more link
    http://www.joethewelder.org/?tag=spoolmatic-1
  5. Likes jackal, skipd1 liked this post
  6. #4
    Aug 2012
    California, Central Coast
    1,220
    1628
    329
    I bought a hossfeld from a guy a couple weeks ago and he had an old spoolgun for a miller, here is a copy of his add. In California, if it is right I can go make sure it runs if you like.
    Welding machines and supplies
    Text of add: Misc. welding machines and supplies. We have a Lincoln AC/DC 250amp welder, Miller SCP200, Miller AC/DC 250amp welder, 600 ft approx welding cable, Ridgid 300 pipe threader, Millermatic WC3 weld control & aluminum wire feed gun, and a Millermatic S-520 wire feed welder with 30 foot cable & hose. Lots of misc weld fittings.
    I deleted his ph# from here but it is in the add.
    Rob
  7. Likes jackal liked this post
  8. #5
    Jan 2010
    Bismarck, ND
    139
    13
    Default Need a spoolmatic 1 spoolgun
    Quote Originally Posted by David J. View Post
    for it.
    David
    Miller - Spool Gun Hookup Chart
    one more link
    spoolmatic 1
    My local Miller distributer "Praixair" said I need the 4pin spoolmatic 1 gun, everything is too expensive to mofify. My millermatic 200 was purchased in 1987
    Skipd1
  9. #6
    Feb 2011
    Michigan
    457
    11
    314
    Did you look at the second link I posted, should open up some options.
    Somewhere between $400---$800 range seems to be where the
    prices are. Might post a want ad on the AWS site.
    David
  10. #7
    Jan 2010
    Bismarck, ND
    139
    13
    Yes I did and thanks, the second link gives me some options
    Skip
