Greetings all,
I've got a part that I make that is a tension knob. Knurled brass, threaded down the axis. It needs to have *some* drag on the thread, but not lock solid. Just enough to keep it from shifting around as the tensioner bites onto it.
Currently, we're drilling a cross hole, and pounding in a slug of nylon weedwacker line. Works just fine, but is time consuming and annoying to do. Especially as we go through about 8-10 thousand of these things in a year.
So I'm looking for suggestions of other ways to defurr this particular feline.
The obvious answer is a castable of some sort. Which leads to two questions: A) *what* castable? and (B) how to do it?
My thought is to take a piece of allthread of the same thread as the nut, grind off a flat spot down to about the root of the thread on one side, then thread a bunch of the nuts on, line the holes up with the flat spot on the rod, and inject the (whatever) then go get lunch.
But that leaves you with a solid slug in the bore, and now you have to unscrew the nuts to get them off the rod. Which may or may not be possible, given the amount of crap that's now in the bore.
I'm pretty sure that's the basics of what I'm going to do, but I'm definitely looking for recommendations for something to use as the castable filling. Urethane of some sort, I'd expect. Ideally something that's not *too* toxic, and will stick to brass.
Any suggestions?
Many thanks,
Brian
Any suggestions?
Many thanks,
Brian
