Need a worm and wheel made
Page 1 of 3 123 LastLast
Results 1 to 20 of 57
    Oct 2010
    Moscow,Idaho,USA
    896
    1043
    373
    Default Need a worm and wheel made
    I called Boston Gear and they told me "We don't do onesies and twosies".
    So, Looking for another recommendation or a forum member who can and wants to do this.
    They came out of a Studer cylindrical grinder.
    The worm is double start and the wheel has 40 teeth.
    The worm has an internal square key slot.
    The wheel has a smooth Id bore as it is a sliding fit on the shaft using a clutch to engage and disengage it from the shaft.
    I will send the worm and wheel to the person who does it so they can take all measurements directly from the originals.dscn0516.jpg
    Thanks,Greg.
    Apr 2010
    Wisconsin
    5,072
    3850
    2784
    I would normally offer to assist right away for a forum member, but we are buried for the next Eight to Ten weeks and simply do not have the time to fit it in. There are a few forum members that can assist you. If you do not find any love from one of them shortly, shoot me an email through the forum and I'll do what I can to assist.
  3. Likes Monarchist, cash, TeachMePlease, Peter. liked this post
    May 2003
    Lambertville, MI USA
    2,131
    828
    811
    What model Studer grinder is this off of?
    Have you contacted United Grinding in Ohio?
    Oct 2010
    Moscow,Idaho,USA
    896
    1043
    373
    Quote Originally Posted by SIP6A View Post
    It's the Type 1 I got from Dave Sicard.
    I've contacted United Grinding and they are working with Studer to see if they can find a manual and any other documentation for it.
  6. Likes Sicardski liked this post
  7. #5
    Jul 2009
    Peoria, IL
    10,120
    30
    7501
    What's wrong with these? Normally a worm and wheel get replaced when one stops turning the other.
    Is this a low backlash application or something?
  8. #6
    Oct 2010
    Moscow,Idaho,USA
    896
    1043
    373
    The grinder was disassembled when I got it so I don't know how well it was turning.
    The worm looks like it was half submerged in water for a few years.
    The wheel has one side of the teeth worn down. You can see the part not worn at the bottom of the teeth.
    The worm and wheel supply power to the table for mechanical traverse and wheel head in feed.dscn0537.jpgdscn0538.jpg
  9. #7
    Oct 2010
    Moscow,Idaho,USA
    896
    1043
    373
    I was thinking about just putting it back together and see how well it works.
    But I'm no expert.
    What do you think ?
    Try these or just get new ones made ?
  10. #8
    Jul 2009
    Peoria, IL
    10,120
    30
    7501
    Ouch. The worm does look pretty nasty. That bronze wheel might go a while, but I would replace them as a set.
  11. Likes rustytool liked this post
  12. #9
    Apr 2010
    Wisconsin
    5,072
    3850
    2784
    OOFDA! You would more than likely be fairly unhappy if you put those back in.
  13. Likes rustytool, JST, MCritchley liked this post
  14. #10
    Jan 2007
    Norfolk, UK
    16,113
    11649
    11069
    Rustytool
    may I just say, if it's ''poverty week'' as long as you can get the pitch on a lathe, it often means altering the gear train ??? .... worm cutting is very little different from Acme thread screw cutting, and something like 4340 prehard will probably outlast you.
  15. Likes Zahnrad Kopf liked this post
  16. #11
    Oct 2010
    Moscow,Idaho,USA
    896
    1043
    373
    Quote Originally Posted by Limy Sami View Post
    Rustytool
    Good idea.
  17. Likes Limy Sami liked this post
  18. #12
    Jan 2007
    Norfolk, UK
    16,113
    11649
    11069
    Quote Originally Posted by rustytool View Post
    Good idea.
    Thanks, another thought - if you decide to go that root, but haven't the gears etc etc that worm pitch should be a piece of cake on a CNC lathe.
  19. #13
    Jul 2004
    Houston, TX USA
    26,657
    Studer AG = German = Metric = Module gearing assumed
    Who ever cuts the worm must have a machine that can cut any metric lead - and of course the cutting tools suited to that
    For instance - Mod 3 has a CIRCULAR PITCH of 9.4248mm - and a two start worm with that profile has a LEAD of 18.85mm (note all multiples of PI)
    Somewhat related 12 year old thread - I have asked for the "invisible" photos and will edit them in here - ON EDIT - sorry, no photos to acquire and edit in
    Making a worm and gear set??
  20. Likes Limy Sami, digger doug, Zahnrad Kopf liked this post
  21. #14
    Jul 2009
    Peoria, IL
    10,120
    30
    7501
    Thank God for CNC aye? Push some buttons and let the 1s and 0s figure it out.
  22. Likes Limy Sami, Philabuster liked this post
  23. #15
    May 2003
    2,131
    828
    811
    I've got a catalog for the type 1 Studer send me your mailing address and I will copy it and get it sent off to you.
    Here is a link to a manual for a Studer OB grinder. This is going to be very similar to your type 1. The difference between the two is the type 1 is slightly larger.
    Studer OB manual 23MB.pdf - Google Drive
    [email protected]
  24. Likes rustytool liked this post
  25. #16
    May 2003
    2,131
    828
    811
    Quote Originally Posted by johnoder View Post
    Studer AG = German = Metric)
    Studer AG = Swiss
  26. #17
    Jul 2004
    Houston, TX USA
    26,657
    Studer AG = Swiss
    I thank you for the correction, though AG, or Actien-Gesellschaft, is from the German language
  27. #18
    Sep 2005
    Oakland, CA
    1,869
    52
    416
    Rustytool- I can make these for you if you decide to go that way. One offs are never low cost, but there are a few options for the worm itself. Not many options on the worm wheel other than using the one you have or making a new one. Being metric is not an issue here.
    Drop me a PM or e-mail me at [email protected] if you decide to proceed. One thing I will need from you is an exact center distance measured off the machine.
    Dan
  28. Likes Limy Sami liked this post
  29. #19
    Jul 2006
    Hillsboro, New Hampshire
    3,780
    764
    2486
    Quote Originally Posted by Dan from Oakland View Post
    Dan
    Dan, when faced with a repair like this is it possible to remake the worm at a slightly larger pitch diameter, then dress the gear down a little to clean the tooth forms? It might have lower life than the original configuration, but given the use would probably work fine.
  30. #20
    Apr 2010
    Wisconsin
    5,072
    3850
    2784
    I know exactly what thread that is. I have been wanting to do that for gits and shiggles since I read his accounting of it, back then. I just want to do it once. That is a great thread, and great idea.
