Shadon
Hot Rolled
- Jul 29, 2011
- Southern Calif US
With the new low NOX requirements here in So Cal we have been struggling with fuel / air ratios and the very fine line between correct operation and emission compliance, new to us now is the Maxon / Honeywell system onboard flame safety / fuel - air computer. This system uses 2 mod motors and an adjustable ratio between the two via a touch screen control, the fuel / air curve can be adjusted on the fly based on the burners firing rate, the days of adjusting linkage for fuel/air ratios are over! A new curve can be set for dual fuel burners if required, just by touching a button to "fuel 2" you can burn an alternative fuel that has its own ratio pre-loaded.
Very slick.
Very slick.
