mikeperrucci
- May 16, 2018
Hey everyone. I have a new 20" drill press and am attempting to tune her up because she was in bad shape when I received her. I managed to get everything in order except for there is a considerable wobble that wobbles the whole press and shes a pretty big press. Id say its around 1/8th to 1/4 wobble. In troubleshooting the wobble I narrowed it down to 1 suspect. I took out the spindle/quill and i sat it on the floor and spun the quill around the spindle. There is a good amount of wobble/ momentum from one side when i spin it by hand. From visual inspection everything seems to be in order except when i place it next to a square the quill is slightly off 90 degrees from the floor (if that makes sense). The only thing I can think of is that when it was put together the bearings are ever so slightly not flush or offset on the spindle causing it to rotate off center. Does that make sense? Any help would be much appreciated.
Mike
Mike
